can any one give me a heads up with the dreamnetcast pulgin ive sucsessfully installed it on an enigma image but can seem to set it up on neutrino Dream+ ultra 0.9b any one got any ideas
dreamnetcast
There should be 3 files.
dreamnetcast.cfg -> /var/tuxbox/plugins
dreamnetcast.so -> /var/tuxbox/plugins
stations.xml -> /var/etc
CHMOD 755 the .so file after copying it to the box.
Reboot the box after copying files and it should be accessible from the plugins menu on the image.
Edit the stations.xml file with your own radio stations if you want. -
Try here...
Tuxbox Commander Useful for editing files on your dreambox. Dream Netcast Internet Radio Listen to internet radio on your dreambox. Edit the /var/etc/stations.xml file to add new radio stations. Dream Weather X Weather information DB Switch If you have two dreambox receivers in the same room you can use this to
The .tar.bz files can be opened with WinRar. Just copy the files in the folders to their respected folders on the box. If it doesn't have an 'Uninstall' folder, don't worry about it.Comment
I must admit, I've never had it running on neutrino. I prefer enigma for the dreambox and neutrino for my dbox2.
EDIT:
Just thought....it might only be fore enigma because if you look at the config file it says...
Code:name=DreamNetcast desc= depend= type=2 needfb=0 needrc=0 needlcd=0 enigmaplugin=1
