again i ask what do u want to edit ?
it can be as simple as ftp'ing your modded file over or you may even need to kill a process before u can change a setting/file, theres no real tut as such be more specific and im sure youl get what u want
bootlogo little harder to do but not impossible but for now try to get a grib of ftp
smart ftp/cuteftp or firefox ftp addon what ever your comfy with
cables.xml goes in /etc
cams go in /usr/bin chmod 755
depending on which image u crurrently have u may have to edit/make a script for your emu to show in the blue button menu otherwise u will have to telnet in to start/stop (which i do recomend u try to get a better understanding of how stuff works)
take a look at /usr/scripts for a example emu script
