pissed off
  • thered
    • 4915
    #16
    • dctyper
      • 2539
      #17
      the pdf file is corrupt, so i can do anything as yet
      • dctyper
        • 2539
        #18
        ok i dont really understand the instructions
        • shady77
          • 982
          #19
          What was your previous image?
          • dctyper
            • 2539
            #20
            ive always used dw2.0 i have tried dk1.1 and the one suggested from the dream website
            • dctyper
              • 2539
              #21
              ok, done a flash erase. i didnt flash another image i just diconnected and powered up. i get a blank screen, so no ss1 picture that keeps coming up, im now flashing my dw2 image
              • dctyper
                • 2539
                #22
                flashed ok, but the frozen screen from ss1 is back!!!!! aaaarrrggghhh
                only difference know is that i can turn the box on standby(even though the frozen screen is still there) poo
                • dctyper
                  • 2539
                  #23
                  job done, fixed, thanks guys. dk1.1 doing its 1st scan now
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    #24
                    Don't JTAG it, that's not needed.
                    Use Dreamup and a null modem cable.
                    Turn box OFF.
                    Run Dreamup and click connect.
                    Turn box ON.
                    Click 'Flash Erase' and let it do it's thing.
                    When it's finished, click 'Flash Erase' again, yes do it twice.
                    Then flash any image you want and see if it works.
                    OR...
                    There is an erase image here, flash that with dreamup and then flash whatever image you want with dreamup.
                    Digital Kaos - Downloads - Erase Image for DM500
                    When your box is ~~~~ed, always best to use dreamup then you know all the memory partitions are set correctly.
                    • father ted
                      • Feb 2008
                      • 1389
                      #25
                      how did you fix it m8?what did you do in the end to get it going?
                      • dctyper
                        • 2539
                        #26
                        flash eras, left it for a while, then flashed it with dk.
                        however, i have put the new roms/k*ys in but no joy. i have a back up of my files but dont know what to do
                        • father ted
                          • Feb 2008
                          • 1389
                          #27
                          did you put them in the right place var/keys or is it var/scce use dreambox edit to place your files in the right place
                          • Devilfish
                            Administrator
                            • Feb 2008
                            • 7872
                            #28
                            All key files go in /var/keys except the nagra*.bin files which go in /var/scce.
                            • dctyper
                              • 2539
                              #29
                              yeh, done all tat. all fine now thank
                              • cowplain35
                                • 138
                                #30
                                My dreambox was freezing as well,as i left it outside last night in the freezing temperatures,i took inside,plugged it in,it's OK now.
