Despirate DM600-C
  • OldF4rt
    DM600 Despirate DM600-C
    This has to be my last try to get my 600 working. I just don't understand why something that appears so simple, getting the POS to work, is such a problem. Simply put I can only see FTA channels. On occasion I've been able to get working images that have then failed at key-roll and never worked again. I had a G-Spot image that worked for a time then stopped and never worked again. My box has spent more time not working than doing what I bought it for.
    I've tried a number of forums (and this is the effing last) and have concluded that either I'm more stupod that I thought or trying to be too clever!
    There are two things that I would like to do:
    1) Be able to build a repeatable image that will decode all channels.
    I've been trying to get help on this on another forum (LIGHT Forum The place to be) - still no joy. It looks like I'm following the right steps but nothing is working!
    2) Understand how the relationship between the feed (signal), softcam, and cardsharing works.
    I've felt that me not understanding how everything "hangs together" is part of the reason that I can't get the DM working as it should.
    OldF4rt
  • mm009b
    • 221
    goto dowloads mate its all there calm down mate
    • smoggie
      • 863
      have a look in this thread, you need to ftp the auto update roms over http://www.digital-kaos.co.uk/forums...x-noobs-14864/ plenty of help here if you get stuck
      • Ebro
        • 67
        I think your just stupid. Everyone else has theirs working..
        LOL
        Sorry. don't mean it, but had to have a laugh. Keep trying, you will get there.
        • Ginkman
          • 93
          stay with it, you are already most of the way there by the sounds of it. You seem to have been able to put and image on the box. Some are more user friendly than others. The CLi is very user friendly.
          You just need to FTP to the box to put in the new roms, you will need to know how to do this as it will be needed from time to time. There are plenty of good guides to be found on here.
          good luck . . . .
          I've got two DM600PVR doorstops...
          • Curious123
            • 2591
            The reason you can't get your dm600c working is that you need to copy these files to var/keys and var/scce rather than the satan keybundle.
            • OldF4rt
              I think I agree with you.
              btw that would be you're
              • jsjazz
                • 13
                Did you manage to get it working?
                If not, there is a PLI Iolite image floating around somewhere that has the updated roms included. Just flash that, blindscan, set channel to Sly Sports 1 and after a few minutes it should work.
                • Aldormanndiobla
                  • Aug 2008
                  • 54
                  Its really simple to do, I can give you step by step instructions if you like.
                  Failing that, I could probably backup my pli Jade image.
                  Real men have FTTH.
                  • dreadfand
                    to the original poser:
                    flash erase your box to digital kaos v1.1
                    ftp (i use cute ftp) the keys to var/keys and the NEW roms to var/scce (found a couple of posts up)
                    in fact heres the link 2 download them
                    RapidShare: Easy Filehosting
                    go to sly sports one hold down info restart evocamd wait 5 mins thats it your done
                    if you do those steps exactly your box will work
                    DREADFAND
                    • Aldormanndiobla
                      • Aug 2008
                      • 54
                      That image isn't for the DM600C, only the DM500C as far as I know. Use the PLI Jade image for the DM600
                      Real men have FTTH.
                      • dreadfand
                        ahhh my bad read it as 500c
                        here's the jade image
                        dreadfand
