Hi again have been busy @ work so not been able to get on line anyhowz i recently got DB500c about 3wks ago but it was an import from china with no pre load after busting my small brain i managed to flash the box with DW dream 1.6.2 do i need to preform a re-flash of the new fix from astra & twobeer cans to get it running again?
dreambox flash
A re-flash won't fix it.
You need to connect the dreambox to your PC, either by using a crossover ethernet cable between the dreambox and your PC or connect the dreambox to your router. You need to use an FTP program to transfer the new nagrarom files to the /var/keys folder.
See the links in my sig, they have all you need to know.
Then once you know what you're doing, or if you're still stuck, see this thread!
Ok guys and gals...I know some of you are still having problems with the auto updating of your keys. You will need to be comfortable with ftp'ing files to your dreambox for this to work. Delete everything in your /keys folder. Extract the /keys folder from the rar. Copy the contents of this keys folder to your own keysComment
