dreamup and iport connect to mine ok can you try another pc maybe
or do you have another box you can try
have tryed starting the programe/dreamup with the box power on then pulling the plug and switching back on
or started the programe with the box switched off then power up he box
so it must be the pc , have you got another pc you can try
even reboot the pc ,see if com port works again
it should work if youve flashed boxes before
Did you even read my post I said I was using a null modem cable and I have flashed boxes with it before so it is obviously A Null Model Cable. And Iv'e Tried A Restart Going To Try A Different Pc Now.
