500c help please
  • Dreamer
    • 2020
    500c help please
    Hi all. I’m a newbie to the dreambox and this forum. I’m a bit familiar with the dbox and I recently got a dreambox 500C after a week the keys changed and I’ve been trying to get it fully functional since then. I put in the dw v2 image and I followed the fixes listed in these posts
    1 AU fix at http://www.digital-kaos.co.uk/forums...ead.php?t=1273 I couldn’t download these(didn’t have enough posts at time) but I believe I already have the correct updated ones.
    2 Changing the camd and mg_cfg as follows
    # AU
    # 00 is ignored (default)
    # 01 enable AU
    # 02 AU Auto
    A: {01} change this to {02}
    2 I’ve edited the keylist.txt file in var/keys with what I believe are the newest keys
    3 I downloaded this rar file with all the var/keys files http://rapidshare.com/files/107724581/keys.rar
    4 I put the 7 10 &11 rom files into the var/keys and the var/scce
    5 I’ve rescanned using bruteforce
    It’s just the same. Any help would be appreciated. Someone mentioned a new DW image. Where can I get it?
    Someone also mentioned restarting EMU is this the same as a box restart?
    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
  • zaf786
    • 327
    Originally posted by Dreamer
    Hi all. I?m a newbie to the dreambox and this forum. I?m a bit familiar with the dbox and I recently got a dreambox 500C after a week the keys changed and I?ve been trying to get it fully functional since then. I put in the dw v2 image and I followed the fixes listed in these posts
    1 AU fix at http://www.digital-kaos.co.uk/forums...ead.php?t=1273 I couldn?t download these(didn?t have enough posts at time) but I believe I already have the correct updated ones.
    # AU
    # 01 enable AU
    # 02 AU Auto
    2 I?ve edited the keylist.txt file in var/keys with what I believe are the newest keys
    5 I?ve rescanned using bruteforce
    It?s just the same. Any help would be appreciated. Someone mentioned a new DW image. Where can I get it?
    Hi restart cam via blue button make sure it,s evocam and reboot your box leave it on sky sports 1
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      OK you're almost there.
      FTP to your box and delete EVERY file that's in /var/keys.
      Now open the rar file that you got from rapidshare and copy the contents of that keys folder into your /var/keys folder on your box.
      Flick to sky sports 1 and reboot the box using the shutdown menu...
      menu > shutdown > reboot now
      When the box powers up, it should start of sky sports one, a window should come up saying 'Starting Evocamd 2.12' then you will get a blank screen. Wait for a few minutes and the channel will come on.
      For some season, I think peoples files are becoming corrupt. Editing them with tuxbox commander and editing them with windows notepad and wordpad. They are linux files and if a windows character get's stuck in there it will screw it up.
      So try that and see how you get on.
      • Dreamer
        • 2020
        I have exited to the menu and pressed blue button but nothing is displayed.
        How do I get to correct menu or place for blue button to work?
        p.s. Have just read your post Kaos. Cheers I'm off to try out you're instructions.
        • zaf786
          • 327
          What image are you using mate
          • Dreamer
            • 2020
            OK I tried that and there is no window with "'Starting Evocamd 2.12'"
            Is it possible I dont have Evocamd?
            • Dreamer
              • 2020
              Dw v2 I think it was released Nov 2007. Is there a newer one?
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                Press OK and you should see at the top what emu you are using. If you don't see anything, I recommend you do a factory reset and it will restore all defaults.
                Then try again.
                • zaf786
                  • 327
                  [QUOTE=Dreamer;10171]Dw v2 I think it was released Nov 2007. Is there a newer one?[/QUOTE
                  I put this in downloads you can try it just follow instructions
                  • Dreamer
                    • 2020
                    Then try again.
                    Now I'm scared!
                    If I factory reset will that delete the dw image I put on? will I still be able to ftp in?
                    Is there somewhere I can look in the file system to make sure I have Evocamd or is it always there as standard?
                    • Dreamer
                      • 2020
                      [QUOTE=zaf786;10177]
                      http://www.digital-kaos.co.uk/forums...do=file&id=163
                      Cheers 4 that I will give it a go. Do I need to dreamup the image with null modem? I've never done that before.
                      I put the last image in via ftp, changing the name and putting it in the tmp folder etc
                      • Dreamer
                        • 2020
                        [QUOTE=Dreamer;10183]
                        I've ftpd the image in and restarted. Still only getting a picture on some channels. I've just started a scan so we will see what happens then. I'm still a bit confused about the Evocamd. I had no problem with my old dbox I could enable different cams on that but I don't see a way of doing it with the 500c.
                        Thanks for your help
                        • smirnoff_rules
                          • 8603
                          dont forget to put on sky sports 1 for a few minutes to auto update
                          • Jaffa
                            • 1612
                            I think it only comes with Evocamd but is possible to put more in is you wish, you can ftp them to tmp and use the user features to set them up or connect your dreambox to your router and connect to the server to do it.
                            • Dreamer
                              • 2020
                              Do you know how I can check the cams? I tried pressing the blue button and nothing happened. Kaos recomends I do a factory reset but I'm a bit scared to do that just yet cause I don't know what a factory reset does. I've got my box on Sky Sports one but it doesn't appear to be updating yet. still no picture or sound on some channels.
