I put the latest mod dw v2 image on. Thanks to zaf786's post. but I don't know how to restart the Evocamd or if I even have one? Is there somewhere in the file system I can look and check
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
With dw 2.0 you should have it if you press Blue button, it should be at the top.
I know you guys will think I'm mad or stupid but I'm new to the dreambox.
If I'm in the tv menu and press the blue button that would give me my bouquets menu. what menu should I be in to check the cam?
press exit m8 , get back to a normal screen then press blue
sounds like a bad flash to me , there has to be a menu fault on it .. do a factory reset and rescan again , or reflash .. l have no idea if that image works . l know the dw 2 one works with a files fix
Don't know what image your running, but in gemini image (or any enigma image) there is an option to use 7000 series type remote, that would account for some of your buttons not doing what they should as they are mismatched. Try pressing the volume +/- buttons and if they open up a menu or something then the chances are that has been selected.
I’ve done the factory reset. It just resets your config, services, bouquets and some other files so it wasn’t too scary and it left the DW image on.
From there I just changed the camd and mg_cfg files, rescanned, rebooted to sky sports 1 and after a couple of minutes---- there was sport.
Looks like a bad flash afterall. Everything is working just fine now and I even know which version of Evocamd I have now!
I done a little dance, patted myself on the back and said a loud “thank you” to all you guys for your help.
