DreamBox 500c channel issues
  • jaba101
    • 13
    Hello All,
    I hope someone can help?
    I have had a Dream-Box 500c for about a year and have been running on DW v1.6.5 (old i know), which has been great up until a week ago when all of the none free-view channels are now displaying a blank black screen. the SNR is about 95% and i have just flashed with Dream Up via null modem the new DW V2.0 modded, but still i can only see the Free-view channels (and yes i have unticked the free option on scanning). Does any one no of any issues in Bristol (virgin) area?
    I have completely re wired the coax and connectors TNA still getting around 95% SNR????
    Please help
    Cheers
    The Newbie
  • Jaffa
    • 1612
    For some reason there seems to be an issue with some people when they flash the new image, you are not the only one. Try what is in the thread below to see if that helps resolve it.
    Ok guys and gals...I know some of you are still having problems with the auto updating of your keys. You will need to be comfortable with ftp'ing files to your dreambox for this to work. Delete everything in your /keys folder. Extract the /keys folder from the rar. Copy the contents of this keys folder to your own keys
    • prawny007
      • 51
      right ive seen too many people thinking that they need to add a new image, nothing is further from the truth, you only need to add the new fix file to your old image. now im presuming that some people might find the idea of flash fxp (ftp) a bit daunting if they have not used it before so heres a little help. this is based
      read up on this bud
      • C64
        • 2394
        @ Jaba101
        Make sure your cam is set to Evocam or mgcamd mate, others will not work.
        • jaba101
          • 13
          Hello Again,
          I can see all the channels know but the they keep freezing?
          Any ideas???
          Cheers
          • smirnoff_rules
            • 8603
            tell us wont cam your using m8 blue button / softcam ok
            • jaba101
              • 13
              Hi im using the evocamd 2.12
              tried the MGcamd 1.22 tna?
              • smirnoff_rules
                • 8603
                the best ones for me where evocamd 2.13 or gbox m8 , but l know alot use 2.12 . if the free channels breakup its not the cams
                • C64
                  • 2394
                  Mate, can u get Gbox to decode with the new roms?
                  I only tried it with Rom7 but it failed.
                  • jaba101
                    • 13
                    i have tried with Gbox and evo 2.13 and the same Free View channels fine but the rest are blanked out ?
                    • smirnoff_rules
                      • 8603
                      dont sound like the fix is installed right then .. did u install the fix or a fixed image
