DM500 Black & White Startup.
  • HoaxKey
    • 16
    When i start my DM500 up for the first time ach day it is usually black and white. All the connections are fine i plug in and out a few times and evntually almost randomly it goes colour sometimes even when i am nto fiddling with the cables. Is this common and will a re-flash likely fix it?
  • mcassidy
    • 47
    Hi. Check AV settings to ensure that S-video has not been set by default.
    Select Menu,Setup,System Settings,AV Settings
    Color Format should be CVBS or RGB
    If is is not then press the left / right arrow keys to toggle between CVBS,RGB,S-Video,YpbPr.
    If S-video is already the selection then it will show black & white.
    Colour format should be CVBS or RGB. RGB is usually better.
    The TV System should show PAL. If not set it to PAL.
    Press green button to save.
    Press exit repeatedly to return from menu.
    • nono_748
      • 61
      Hi,
      I was the same problem 4 months ago when I received my DM to dvb seller with the original image.
      I sent nemesis 4.2 and the DM work fine.
      Hopefully your scart connection.
      Nono
      Atlas HD200se F404
      vu+ solo suptv + Ncam for TNT card V5 openpli 4.0
      vu+ zero script openpli 6.2
      Sunray 4 openpli 7.0 suptv
      • jali466
        • Apr 2011
        it not work for me
