How to JTAG a DM500
  • sirpanos99
    DM500 clone and latest gemini image
    Is gemini 4.7.0 ok to flash in a DM500 clone?
    • pepperr
      • Apr 2011
      I have problem with jtag. After flash dm500s still can ligth the green button, It flashed green for the last 2 % of flashing, and when I plug it again in power switch, dm500s is dead no light. Tuner is alps model BSBE1-702B. I'm using dos program 2aps.inf.
      • Gizzy68
        • Apr 2011
        In the 500c box i try to flash, have NuTune tuner and no result. I have fix manny boxes with the same jtag cable and same computer and apps but thats boxes have alpa and a philips tuner, is it someone who has succesed whit this NuTune tuner ?
        • aabid
          • Apr 2011
          • 6
          #604
          I have jtagd dm500s and green light is gone but still cant connect it with dreamup.Could it be bootloader file I used.Please help I have been reading lots of posts but still dont know what the problem is.Thanks
          • invader7
            • 12
            #605
            can i use this guide for optibox 550s clone ?
            • steve555
              • Mar 2009
              Dos JTag
              Originally posted by oppekepenne
              My DM500s can't light green lamp.So I make JTAG and connect succesed.
              But 2alps.bat stop process at "Erase Flash done"
              wait long time. isn't display "download....0%"
              please help me ***65374;!!
              Flash Info : INTEL Unknown
              ***12539;***12539;***12539;***12539;***12539;***12 539;***12539;
              ohh!!
              I wait 3 hours "download....28%"
              and +5 hours ""download....39%"(total 8 hour)
              My PC is Interl Celeron(R) 1.7GHz 256Mbyte RAM. NOT eough?
              CPU availability 99% Not use applicaton soft.
              Cause JTAG communication? (JTAG cable 9cm)
              PC spec?
              PC setting? (Bios paralle port OK. not use printer and haven't installed driver.)
              dream box? (updated gemini 4.40 flash image)
              i could complite download 100% (about 24 hours)
              but green lamp is dark.
              cannt coummicate by rs232 LAN.
              I used jtag_windows v0.1. but "ERROR:resister test failed"......
              Timming is difficalt. Turn on(switch) : connect click?
              Many try
              Something time
              ===>cpu seem to be ok
              *** Memory chek ****
              Flash Memory ID's do not match!(should be 0x89 ans 0x17)
              As you sure thi is a Deambox DM7000S?
              help me
              I am having the exact same problem... i have left mine for 3 hours now and its not even displayed 0% still stuck on erase flash done. Has anyone got any ideas? Thanks.
              • SHANIS
                • 6
                #607
                Hi guys
                my d500 was working fine but i couldn't connect the box with serial cable, so i have flashed the box with ftp and it was working fine .
                I ahve flashed the box again with diffrent img with ftp and now the box come on and after displaying bootup picturte tv screen goes black nothing work.
                normaly my other box comes back alive with serial cable flash but this one doesnt connect with cable so i can't flash another img.
                box comes on but after few second nothing comes on.
                So do i need to use Jtag ?
                • mikulas7
                  • Aug 2011
                  • 4
                  #608
                  Originally posted by SHANIS
                  Hi guys
                  Yes you need to JTAG it ...
                  You have detailed instructions at h**p://www.digital-kaos.co.uk/forums/f34/how-jtag-dm500-1954/index8.html
                  • mikulas7
                    • Aug 2011
                    • 4
                    #609
                    Originally posted by doki
                    Hi All,
                    I have probelm with 500c to make Jtag for that,
                    1. Can someone write a ling to download the files that I need after connect the PC to dreambox as described here.
                    2. If to make jtag for 500c and 500s are the same?
                    thanks,
                    doki
                    FOR DM500S, if your intel flash is JS28F640, use the dos program. Only for DM500S, sat tuner because the bootloader is for sat tuner. For TE28F640 flash chip, you can only use the jtag window program, load the right bootloader for your tuner, ALPS and Philips is different. Change the 000000000 to something like 00:09:34:??:??:??.
                    For DM500C, CABLE bootloader is diff from SAT. only 1 file for the tuners.
                    • mikulas7
                      • Aug 2011
                      • 4
                      #610
                      Originally posted by gmarg
                      Trying to Jtag my DM500S with jtagdm500.exe but after flash erase nothing is displaying in the screen (no upload etc.) Any ideas???
                      After JTAG you must upload an image with DreamUp ...
                      With JTAG you did just upload the bootloader ... I think ...
                      .. fighting with some similar problems ...
                      • mikulas7
                        • Aug 2011
                        • 4
                        #611
                        JTAG
                        So ... here is my story :
                        First of all I JTAG-ed it correctly and flashed up with windows progy ... but nothing happend .. so I flashed it a few more times ...
                        Then I found the DOS progy ... but did not know is it Alps or Philips I have ...
                        So I flashed with both a few times .... ( I think I have Alps .. after I read a few hundred site's about it .... )
                        It's flashed now in DOS/Alps ... but still cant reach it with RS-232 DreamUp ...
                        Any ideas ?
                        • SHANIS
                          • 6
                          #612
                          Thanks for the reply bro
                          Even if i use Jtag, I don't think i will beable to upload the image through Dreamup ? bcz my serial cable connection doesn't work on this box...I use to upload image through FTP.
                          Is there any way to falsh the image through Jtag?
                          • henriqueramone
                            • Aug 2011
                            It may not be dead, right?
                            I went to upgrade mine, time to restart, do not start anymore. By connecting the DM500S at source, the Green LED is lit directly. I tried with the serial cable, but does not connect dreamup. Anyone know how can I solve this?
                            • mtv1
                              The Stig PT
                              • 4413
                              #614
                              try an older version of dreamup the one on my siggy works on the 500s keep trying and good luck
                              • fyrdaxus
                                • Sep 2011
                                dm 500s problem
                                hi all, my dm 500s have a problem..the blue light permanently on.,.remote control also cannot function on my dm.
