How to JTAG a DM500
  • jatrophaseed
    • May 2010
    • 589
    #661
    Dont hv this usbjtag, no harm trying if yr box is already bricked. The min necesary connections r there.
    Sent from my GT-S5830 using Tapatalk
    • jiangou2007
      • Oct 2010
      • 37
      #662
      anyone with successful window Jtag experiences to share?
      • rpaldo
        • Sep 2012
        yes its work fine!!!
        • apettas
          • Oct 2012
          I hope this will work because i don;t see any other solution
          • fitoguitar
            • Oct 2012
            Originally posted by jbvid
            Are you using a Null modem Cable with Dreamup software to put a new image onto the dm500 ????, (Untick use network) this is the only way after Jtagging in a new bootloader.
            You cannot use FTP to load image.
            If still struggling you could have a hardware problem if no lights on box.
            UPDATE : Try this lot (Attached) for DM500 Cable, it worked on mine
            jbvid
            Great, let's give it a try!
            • ninoumouad
              • Nov 2012
              thanks for this thread
              • josepablo
                • Nov 2012
                i have this one too, and i dont know haw to do
                C:\Dreambox\Jtagdm500>jtagdm500 -m dm500 -e 00:09:34:00:11:22 -c
                Dreambox Dm500 board initialize
                Flash info. : INTEL JS28F640J3D75
                [dm500] reading CA:03 ff 07 ff 0f ff 1f ff 3f ff 7f ff ff ff 00 10
                [CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
                Readed Config Area
                Configuration Area
                Mac Address: 00:09:34:aa:0b:cc
                Redunderant Mac Address: aa:0b:cc
                Tuner Type alps
                Mac Address Change Requested
                Commit Config Area
                Configuration Area
                Mac Address: 00:09:34:00:11:22
                Redunderant Mac Address: 00:11:22
                Tuner Type alps
                Erase Flash. done
                • servotell
                  • Dec 2012
                  i have a dreambox dm500s . every 3 sec. do a restart; do u think i kan use the same method to flash with jtag adaptor?
                  • cgscott
                    • 3513
                    #669
                    just use a null modem cable and dreamup to flash new image. Your image is corrupt. Does not require JTAG.
                    Patience is a virtue.
                    • mazalini
                      • Dec 2012
                      dm500-s
                      Please help
                      dreamup not conected dm500s
                      Yes Yes i find problem
                      pin contacts for com ports 2 and 3 shilded other side. disconect en dreamup working fine
                      • sehli
                        • Dec 2012
                        hello,
                        that's it what i need. i hope it will work because it's my firsttime.
                        thx
                        • styler1234567
                          • Jan 2013
                          jtag!!
                          where can i buy jtag ?
                          • Birkof007
                            • Jan 2013
                            My DM500s has not any JTag connector.
                            • jatrophaseed
                              • May 2010
                              • 589
                              #674
                              No connector pin, use pogo pin only for yr jtag. Read back for more info n jpg.
                              • miti55
                                • Aug 2011
                                I have same problem. Can you help me with jtagDM500.exe?
                                Thanks!
