I AM TRYING TO SET UP MY 500C USING THE NOOBS GUIDE. I FLASHED THE IMAGE FINE USING DREAMUP AND A NULL MODEM CABLE. WHEN I TRY THE NEXT BIT WITH FLASHFXP AND A CROSSOVER ETHERNET CABLE (DIRECT TO MY PC) I CAN NOT GET IT TO CONNECT. I HAVE READ EVERYTHING I CAN FIND ON HERE AND TRIED MANY THINGS. I GET A VARIETY OF ERROR MESSAGES, THE CONNECTION IS EITHER LOST,TIMED OUT, OR REFUSED. IS IT A SETTING ON THE BOX? PLEASE HELP AS MY WIFE WANTS TO KILL ME!
PLEASE HELP A NOOB
your ips dont match.
set your box as............192.168.1.100
set your pc as .............192.168.1.101
subnet mask on both......255.255.255.0PS3= krazylegz120282
if you like what people say please use the reputation or thanks button, dont just make a post to say thanksComment
dreadfand -
double check your crossover cable it should be wired in this way.......
cable end (A) white/green - green - white/orange - blue - white/blue - orange - white/brown - brown
cable end (B) white/orange - orange - white green - blue - white/blue - green - white/brown - brownComment
Hi,
I have just began to get further with my dreambox....
All i can say is for me.....
Use a wireless router directly connected to your dreambox and wirelesly connected to your pc/laptop.
reset/reboot your dreambox, router and laptop to correcly get your new ip addresses.
Then once all are connected, go to your dreambox and;
MENU>SETUP>EXPERT SETUP>COMMUNICATION SETUP
.....And note your Dreambox IP.
Open Flash XP,
Left hand colmn has your computer...right hand column is blank.
Click on the THUNDER icon in the right hand column (Quick connect or F8)
Type your dreambox ip (noted earlier in the Server or url)
Example 192.168.1.3
User name: root
password: dreambox.
Then click connrct...
If it works then cool and try next step to ftp to correct location.
Hope this helps
dreadfand
Hi,
Open Flash XP,
Example 192.168.1.3
User name: root
password: dreambox.
Hope this helps
yeah that's a fair point but really with a crossover cable it should be just as simple......I'm sure if you google setting up crossover cable or something similar you will get in depth instructions and a idea where you may be going wrong.
dreadfandComment
