Messed up Dream Box
  • ema153
    • 9
    Messed up Dream Box
    Hi, I think I have messed up my deram box 500c I no longer get the intro screen when I switch on. Can someone please tell me if there is a way to re-install the Dream Worldz Dream 1.6.5. Many Thanks in advance.
    Last edited by ema153; 28 April, 2008, 12:23. Reason: not set instant notification
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    You can reflash the image using Dreamup and a null modem cable.
    There's a guide here...
    How Do I Use Dreamup? If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug
    • ema153
      • 9
      Many Thanks Kaos
      • ema153
        • 9
        Hi, sorry I am thick but where do I get the image file from for the D500C. Thanks again in advance.Can I get an image from a working Dream Box, if so How. Thanks again.
        • caveman_nige
          • Feb 2008
          • 4920
          Try this one mate...
          • ema153
            • 9
            THANK'S NIGE ILL HAVE TO TRY THIS LATTER WHEN I HAVE MORE TIME ILL LET YOU KNOW I GET ON WITH IT
            THANS AGAIN EMA.
            • ema153
              • 9
              Hi, Have just managed to get my dreambox working, booting up and it has found the channels, however even though I have updated the key file using nagram7 as I did with my mates, whose box had version 1.6.5 Dreamworldz and his worked mine has not. What do I need to do please. Many Thanks in advance.
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                Make sure the auto update is set to { 02 }.
                Ive recently installed the "nagrarom7.bin" file.. I was wondering how will I enable the AU { 02 } in the camd_cfg file and mg_cfg file? Where are these files located? Cheers
                If you edit any cfg file, restart the emu or reboot the box using the shutdown menu.
                • ema153
                  • 9
                  Hi Kaos, thanks for all your help so far but I am still having problems, I have done what you said regarding the other nagracom files and the auto to 02 but still no joy with the decoding of channels. Any other ideas would be most appreciated. By the way, if I was to save the image of my mates box and then install it on mine would this solve my problem. Again many thanks in advance.
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    Yes that would solve your problem.
                    Or you could grab the keys folder from here and try that.
                    Ok guys and gals...I know some of you are still having problems with the auto updating of your keys. You will need to be comfortable with ftp'ing files to your dreambox for this to work. Delete everything in your /keys folder. Extract the /keys folder from the rar. Copy the contents of this keys folder to your own keys
                    • bbhs
                      • 33
                      The backup will work - is your mate in the same area ??
                      Also sometimes they do take a min or two to kick in - have you left it on an encrypted channel to build the keys up ??
                      • ema153
                        • 9
                        [QUOTE=bbhs;12809]The backup will work - is your mate in the same area ??
                        Also sometimes they do take a min or two to kick in - have you left it on an encrypted channel to build the keys up ??[/QUOT
                        Thanks for all your advice i did the back up from my mates box & it worked
                        all we had to do then was to add the keys once again manny thanks
                        • jamiemoonie
                          • 6
                          dreambox help
                          you said you need help yes you can fix that very easily just re install what you done the first time do a full scan and erase
                          • Donnie Darko
                            • 442
                            [QUOTE=ema153;14336]
                            Add the keys file?or manually add the keys.
                            Checkout the RED stickies massive amount of info and effort been put into them.
