don't forget to buy a crossover cable, I would also recommend having a null modem cable as well mate its a life saver... if you do not have a serial port (rs232) connection on your laptop or PC then you will also need a USB to serial adapter so that you can use a null modem cable...
you will need to add the roms when you get your box.. A crossover cable is a typoe of ethernet cable that allows you to connect your box direct to your pc without having to user a router
