White FY HD-800C
This topic is closed.
  • patdog112
    • Jun 2012
    • 6
    White FY HD-800C
    Any bros using White FY HD-800C in SG?
    Encountered any problem? I just ordered one
    New Arriving -New FY HD 800C white Color for Singapore
  • DBTraitor
    • Feb 2011
    • 616
    well, the problem is sometimes buggy.
    Some member said eurocup doesn't stay after scanning. Next day it will disappear and you need to rescan....
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • patdog112
      • Jun 2012
      • 6
      should had done more research before committing..
      now I am waiting for a buggy brick to arrive
      • DBTraitor
        • Feb 2011
        • 616
        yes, your box is quite ex
        You can find FY800C-II for USD$120 on aliexpress
        Anyway, there is nothing to play with for FY800
        The firmware and interface is pretty much fixed
        • mRSlow
          • Jun 2012
          no problem with the box for the time being. but i use thumbdrive to record but could nt play on pc. . anyone knows how to slove the problem ?
          • mk9833
            • Jul 2010
            • 19
            Hi, anyone had this problem after i did a scan of the channel everything is okay, only after the next day I only have green light on the box with no screen....
            • moronicgenius
              • Jun 2012
              • 54
              still same problem?
              • patdog112
                • Jun 2012
                • 6
                received this box
                EURO 2012 HD channel is not working well , SD is working fine though
                other than that every channel is watchable
                i wonder should i go source for new firmware or leave it as it is?
                • omarianne
                  • Jun 2012
                  in my opinion saty far from the trouble.any way the euro is not forever . if the other chanels are working what you need more
                  • uu161
                    • May 2012
                    • 372
                    Originally posted by patdog112
                    received this box
                    FY800C-II no problem
                    my first set FY800C-II
                    my 2nd set DM800se (clone)
                    go for dreambox alof thing to play example:
                    host web base streaming and watch outside even not at home
                    if you like the post use the Like button located bottom right corner of each post
                    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                    • moronicgenius
                      • Jun 2012
                      • 54
                      received this box
                      Pic quality issue? if so may be change ur TV cable to RG6.
                      I did that and my STB now ok. hope this helps.
                      • moronicgenius
                        • Jun 2012
                        • 54
                        white FY HD800c is advertised to haf EPG and chinese support. can owners confirm these? I have FY HD800c-ii but no haf these 2 functions.
                        • patdog112
                          • Jun 2012
                          • 6
                          I don't know which tv cable i am using.. but i using HDMI from box to TV
                          while cable from box to cable point is some cable provided from sickhub last time
                          • patdog112
                            • Jun 2012
                            • 6
                            EPG is working fine
                            • Jolor69
                              • Jun 2012
                              Bros, I use FY HD-800C white box. Working fine except some Hd channels, like Fox Family many time become pixelated. Also in the seller store in Aliexpress, the receiver is FYHD800-C II HD receiver. Means version 2. Which is is correct?
                              FY HD800 C Singapore HD TV Receiver FYHD800C-in Set-top Boxes from Consumer Electronics on Aliexpress.com
