E2 SGSH online bouquets updater plugin for sg
  • Logger
    • Feb 2011
    • 92
    #136
    I also update to the new plugin. But stuck on the + exec screen. Then when i reboot, all the thing are gone.
    • uu161
      • May 2012
      • 372
      #137
      Those who got problem on e1 or e2 plugin del all bouquets would u kindly post which ISP are you on?
      As for my side have no issue on sunshine fibre broadband for plugin updater.
      first timer use on 0.3.2 will take a little bit longer it because picon remover script are removing all picons After first run it should be abit faster.
      The above are apply for e2.
      remove all picons will let it run for awhile in furture will be more easy for me to do a individual remover un-use picon
      as for now i won't know what picon u had on it and in before
      ** for those doing customize picon remember to backup if not it will be remove aswell **
      if you like the post use the Like button located bottom right corner of each post
      if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
      • sukmano
        • Mar 2012
        • 10
        #138
        Using singtel exstream fibre ... Still not updating correctly
        • uu161
          • May 2012
          • 372
          #139
          then should be ur isp
          work fine on sunshine fibre
          • noti
            • May 2010
            #140
            What is the freq for 563 : Comedy Central Asia HD and
            875 : KBS WORLD HD.
            • ypvs125
              • Dec 2010
              • 506
              #141
              I ran the plugin and are also facing this issue with sgtel. Edited the script to point to another download server and all is ok. I found no problem on the server part so I guess should be the isp.
              • uu161
                • May 2012
                • 372
                #142
                Originally posted by noti
                875 : KBS WORLD HD.
                563 :458 vpid:1900 apid:1901
                875: 458 vipd:1920 apid:1921
                • uu161
                  • May 2012
                  • 372
                  #143
                  would u give a try changing sgtel default dns to Google Public DNS see it work?
                  A free, global DNS resolution service that you can use as an alternative to your current DNS provider.
                  Master ypvs would you pm me which server that point no problem? thank you
                  • DBTraitor
                    • Feb 2011
                    • 616
                    #144
                    does that mean that the previous server was block or they are doing some maintenance?
                    Anyway, this is the latest bouquet for E1 (500C)
                    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                    • Logger
                      • Feb 2011
                      • 92
                      #145
                      I had try your method, but your server is not responding. *sigh
                      • uu161
                        • May 2012
                        • 372
                        #146
                        maybe maintenance
                        normally it took hours to next day will be back to normal it happen to sunshine before
                        some web might take a while to load or even not loading at all
                        well too bad am not on sgtel i wouldn't know
                        • uu161
                          • May 2012
                          • 372
                          #147
                          just take note changing dns are on router or dreambox not desktop for this issue
                          faster way change from router
                          • Logger
                            • Feb 2011
                            • 92
                            #148
                            Too bad, my 2wire router advanced gateway was locked by SGnet technician login password
                            • uu161
                              • May 2012
                              • 372
                              #149
                              then mean time use DB edit to load bouquet from
                              Master DBTraitor
                              http://www.mediafire.com/?9kj6947txjyuj0r
                              tomorrow if u want to try plugin again update us
                              • DBTraitor
                                • Feb 2011
                                • 616
                                #150
                                Hi Bro
                                What kind of server should i look out for when uploading bouquet. I see that you use hostei which is quite simple and easy to use. Is that consider a ftp server? I see lots of website providing server with a fee. But got different servers, I am confused
