E2 SGSH online bouquets updater plugin for sg
actually i did make a few picon for BPL
in the end i choose m*o stadium as picon
if u guys don't like m*o stadium picon then download this set of picon below
rename ur own service reference
removedLast edited by uu161; 21 August, 2013, 16:32.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
go to SLT basement shop ask them to recommend
however before buying give a trial and error first like
1) change another coaxial cable
2) try others coaxial point
3) may try others image
4) then buy booster
perhaps signal be fixed wait till the day kick off?Last edited by uu161; 7 August, 2013, 07:37.if you like the post use the Like button located bottom right corner of each post
If I had installed the 0.3.3 version of the online updater plugin, and now I wanna install the 0.3.4 version, must I uninstall 0.3.3 first? If yes, how to do it?been trying for a few days online update & finally got it..!! tried so many other ways such as flashed new image, upload master Astrobox bouquet & do online update but still no go.. i just upgrade my ahtel internet to fibre broadband last week.. could it be becoz of dat..?? in the end what i did was installed back previous sgsh online update 0.3.3 & tried update & as expected got all blank.. then installed to 0.3.4, do online update & got it..!! btw all this not using my fibre ahtel but using my vonet wifi on my sunshine ipad hotspot..Comment
Found the reason why picture quality for 226-228 was so terrible.
Rescan for freq 135.00 MHz instead of 135.50 MHz. Same symbol rate 6090.
That solved my problem. I'm using a MVHD HD800C-V.Comment
good finding
yes freq 135 seem signal are better
Sgsh online updated 08.08.2013
226 to 228 changed Freq to 135.00 ( signal seem better )Last edited by uu161; 8 August, 2013, 08:50.if you like the post use the Like button located bottom right corner of each post
hi agallivant your 226-228 scanned from 135 is watchable? I rescan with 135 found signal is stable during scanning but channels still unwatchable.. freeze,distortion,etc.. same as what I have since scanned 135.5 few days agoComment
