E2 SGSH online bouquets updater plugin for sg
  • uu161
    • May 2012
    • 372
    #571
    Originally posted by pspower
    Hi Master,
    If I am not able to locate channels 232 and 233 using freq 150, does that mean my signal is weak thus not able to find these channels?
    previous pages of post i did posted why cannot find
    HInts start to find from page 31 onwards
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
    • uu161
      • May 2012
      • 372
      #572
      actually i did make a few picon for BPL
      in the end i choose m*o stadium as picon
      if u guys don't like m*o stadium picon then download this set of picon below
      rename ur own service reference
      removed
      • SiaoLah
        #573
        actually what kind of signal booster is best?
        • uu161
          • May 2012
          • 372
          #574
          go to SLT basement shop ask them to recommend
          however before buying give a trial and error first like
          1) change another coaxial cable
          2) try others coaxial point
          3) may try others image
          4) then buy booster
          perhaps signal be fixed wait till the day kick off?
          • jnashville
            • Apr 2012
            • 70
            #575
            Originally posted by Asbar
            been trying for a few days online update & finally got it..!! tried so many other ways such as flashed new image, upload master Astrobox bouquet & do online update but still no go.. i just upgrade my ahtel internet to fibre broadband last week.. could it be becoz of dat..?? in the end what i did was installed back previous sgsh online update 0.3.3 & tried update & as expected got all blank.. then installed to 0.3.4, do online update & got it..!! btw all this not using my fibre ahtel but using my vonet wifi on my sunshine ipad hotspot..
            If I had installed the 0.3.3 version of the online updater plugin, and now I wanna install the 0.3.4 version, must I uninstall 0.3.3 first? If yes, how to do it?
            • Asbar
              • Jun 2012
              • 60
              #576
              no just install latest version.. it will overwrite itself..
              • jnashville
                • Apr 2012
                • 70
                #577
                Okay thanks
                • jnashville
                  • Apr 2012
                  • 70
                  #578
                  realise once i reach home all my channels are working. no need me to reconfigure.
                  • tltang13
                    • Jul 2010
                    • 7
                    #579
                    FYI... only HD box can watch B*L
                    • stanleywoon
                      • Oct 2012
                      • 16
                      #580
                      Thanks master uu161, updated bouquet via plug in, 226 - 232 are working very well as of now...
                      • goodlands
                        • Mar 2012
                        • 52
                        #581
                        Noise ratio has really gone up for 226-8 ... Pixelation and breakage happening even with booster ...
                        • goodlands
                          • Mar 2012
                          • 52
                          #582
                          Thinks its coz of the Liverpool v/s Valerenga match... With more ppl watching on the same freq, the signal rate really goes down, becomes totally unwatchable.. I just hope they move to a cleaner freq..
                          • Agallivant
                            • Aug 2013
                            • 8
                            #583
                            Found the reason why picture quality for 226-228 was so terrible.
                            Rescan for freq 135.00 MHz instead of 135.50 MHz. Same symbol rate 6090.
                            That solved my problem. I'm using a MVHD HD800C-V.
                            • uu161
                              • May 2012
                              • 372
                              #584
                              good finding
                              yes freq 135 seem signal are better
                              Sgsh online updated 08.08.2013
                              226 to 228 changed Freq to 135.00 ( signal seem better )
                              • moronicgenius
                                • Jun 2012
                                • 54
                                #585
                                hi agallivant your 226-228 scanned from 135 is watchable? I rescan with 135 found signal is stable during scanning but channels still unwatchable.. freeze,distortion,etc.. same as what I have since scanned 135.5 few days ago
