transponder found, but no channels
  • Krypton
    • 694
    bit of a strange one here guys and gals.
    flashed a 500c for a mate, transpnder found ok, but no channels are coming up on search.
    connection is fine and box has been reflashed.
    i would assume that as the scan found a valid transponder, then finding channels should be childs play!
    box is running dk 1.1
    any help for this weird issue?
    just had a thought. as i say, transponder is found but no channels when scanned. could this be a tuner issue? its not a screw type tuner on this particular box, but an rf.
    Khan, you bloodsucker! You're going to have to do your own dirty work now, do you hear me? Do you?
    Chuck Norris has two speeds: Walk and Kill
    There is no "Ctrl" button on Chuck Norris' PC: Chuck Norris Is always in control
    Evolution is a myth. There are only the animals Chuck Norris has allowed to live.
    Chuck Norris does not sleep: He waits
  • red devil
    • Oct 2008
    • 690
    are u gettin any fta channels, if u are its prob not the tuner
    • Krypton
      • 694
      no mate no fta no nothing.
      ive done loads of boxes before and this is the first time ive come across this problem. box finds and locks onto transponder, but pulls in no channels whatsoever. this makes me think the tuner is working, but is just not strong enough to pull in the channels. ive told my mate to try scanning when box is hooked up to a booster and will wait to see what he says.
      cheers
      • Krypton
        • 694
        ok. booster used, no channels on scan. back to me, using my back up image have flashed twice, once using dreamup and null modem and once via telnet.
        same problem. transponders are found. but no channels
        • Krypton
          • 694
          ok ive sorted it. i have always used brute force on 6887. turns out this was my problem. i scanned on surrounding areas, came to stafford, and lo and behold, everything is there.
          thanks anyway
