Guide: Flashing a Dreambox with Dreamup
  • djam
    • 6
    #166
    Hi need help have brand new dm500 t living in cork ireland can someone tell me how to setup from the beginning to the end my provider is c..s thanks for helping
    • djam
      • 6
      #167
      hi guys,anyone can help me .i flash the gemini image already in my dreambox500t but ido not known how to flash the evocamd 2.17
      • mccoy_ar
        • Jun 2009
        RS232
        What is the different between two cable and how to modify the RS232?
        • glic83
          • 329
          #169
          where are you based mate?i could send you a back up of my dw 2.1 image if you want,it would be handy if you could flash it withh dream up though
          • ferchu
            • Jun 2009
            #170
            Change the port!
            • csacsi72
              • Jun 2009
              very best! I want sharing, plese give me some info
                No sharing talk allowed in the forum m8.
                • fez1975
                  #173
                  Hi,
                  I have just ordered a DM500c from dvbmonkey and a null cable from maplins ready to flash the box using the dreamUP software. I have read the guide and all seems to be straight forward but do I need a downloaded image to start with or is it all within the dreamUP software?
                  Thanks in advance
                  • leskent
                    • Jun 2009
                    #174
                    Thanks for the tut just bought a dreambox 500c and without this forum I would not have had a clue how to flash it and get it working.
                    so great work and thanks again.
                    Lez.........
                    • mr.mojorisin
                      • 247
                      #175
                      after much messing about i finally done it...
                      BOOM...bought Null Modem Cable
                      BOOM...bought crossover cable
                      BOOM...read a lot of threads
                      BOOM...downloaded correct stuff
                      BOOM...flashed image with Dreamup (null modem)
                      BOOM...put correct files in correct places with FlashFXP (crossover)
                      BOOM...scanned for channels
                      BOOM...restarted evocam and tuned to sly sports
                      BOOM...channels up and running
                      A BIG thanks to all who helped and all the guides/downloads etc without which i'd be seriously fcuked.....CHEERS....
                      • anismohamed
                        dreambox 500c and 500s are they the same. thanks
                        iv got the dreambox 500 c im starting to get tyhe image but is the files for the 500 s are they the same
                        • BRASS EAGLE
                          • 307
                          #177
                          hi mate followed your exelent guide ,a bit stuck now whare can i get an image from ??
                            Take your pic m8 Digital Kaos - Downloads - Images
                            • fez1975
                              #179
                              Got the box and did some reading on the forums / guides and the box is spot on and couldn't be happier!
                              Big thanks to all for the guides
                              • jhaye2x
                                • 12
                                #180
                                dreamup software
                                Originally posted by Devilfish
                                How Do I Use Dreamup?
                                If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug half way through (yes it did happen to me). This will get you back on track.hi, i have downloaded the dreamup software.put my null modem cable in,turned off the power.everything is ok until it gets to( initating flash loader upload) and thats as far as it gets.i turned on the power when it says to.it will no initate the flash. any ideas.. jhaye2x
                                Required
                                • Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
                                • Image File (.img)
                                • DreamUp Program
                                Instructions
                                • Disconnect all cables from your dreambox, including the power
                                • Connect the null modem cable to the dreambox and to your PC
                                • Load Dreamup.exe
                                • Click Connect and you will see a message like this
                                • Connect the power and the bootloader should be copied to the box
                                • The message should now say 'Box attached and Ready'
                                • Click Flash on the right hand side and select the image to be flashed
                                • Click Yes or Ya (depending on the version)
                                Note: If you're flashing a backup image, select NO.
                                • The image should then be uploaded to the box
                                • There will be a countdown timer at the bottom of the program
                                • After the image is uploaded, it will be flashed to memory
                                • The finished process should look like this:
                                • Click OK and close down Dreamup
                                • Power off the dreambox for 30 seconds then power up
                                • If any errors appear, check all cables are connected properly and repeat the process but do not use the PC while it's running
                                Good Luck!
