Guide: Flashing a Dreambox with Dreamup
  • harky
    • Mar 2010
    • 226
    #571
    make sure is a cross null modem cable.. (not normal standard RS232 cable) http://www.digital-kaos.co.uk/forums...elp-pls-20624/
    and this is the steps guide http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
    Forum Rules
    • piopat
      • 708
      #572
      a crossover cable is different to a null modem cable ,and buying a crossover cable is no guarantee you can flash your box . a crossover cable is used for some thing different really.
      • harky
        • Mar 2010
        • 226
        #573
        just ask for the cable?
        Forum Rules
        • harky
          • Mar 2010
          • 226
          #574
          in store they only sell null cable cross or straight
          to correct what i mean is
          The correct one "null modem" is cross configured RX/TX and thats what is required. A standard RS232 cable will be straight through.
          Forum Rules
          • ypvs125
            • Dec 2010
            • 506
            #575
            Originally posted by huiswift
            Hi All,
            I've went to SLS to purchase a null-modem cable.
            As below,
            But once i power up more dreambox, nothing pop up and the bar is not running. Why is that so? Im quite confused with null modem cable and serial cable. On the packaging itself , is called as serial cable Female/Female. I've tried plugging into my PC and dreambox. it fits.. but the only thing is it can;t connect.
            Pls advise.
            I was having the same issues as yours the first time and thought have bought the wrong cable or dreamup was not compatible with win 7.
            What i do for it to work is to start dreamup with the power unplug from the box. Once press connect on dreamup, then i start to plug in the power cable to the box. Maybe you could try this and ensure is a null modem cable.
            • nchamoh
              • Feb 2011
              #576
              I am trying to flash my dm500, it says upload completed waiting for acknowledge..... any help with this will be highly appreciated
              • harky
                • Mar 2010
                • 226
                #577
                try other version of dreamup as some work on u some dont.
                Forum Rules
                • nchamoh
                  • Feb 2011
                  #578
                  Thanks mate have tried other at least three versions but no smiles
                  • harky
                    • Mar 2010
                    • 226
                    #579
                    could it be ur null cable plug lose...?
                    Forum Rules
                    • rrct
                      #580
                      hi sorry, im new here. does the flashing helps to the recent problems of DB? thanks!!
                      • Jonis
                        Is the Dreamup software able to flash the dm900c model?
                        • djenga
                          flash 7020
                          looking new version of enigma for dm 7020
                          • rae07
                            • 4
                            #583
                            Hi, thanks for great guide. I've tried using Dreamup but I got stuck right after "loading flasher" or something like that. Dreamup was able to detect my dreambox 500 as recorded in the log box below the program.
                            It stayed there for bat 20 mins and couldn't proceed. I've tried dreamup ver. 1.2.2, 1.3.3.0 to 1.3.3.3 and .3.3.7 none of them works.
                            Anyone can help? I got a null cable frm eBay but can't confirm if it's one.
                            • erwinseow
                              #584
                              Sorry if this has been mentioned before.
                              Can I just flash the Dreambox with just a NULL modem cable? Or do I need to connect both the null cable and the network (ethernet) port?
                              Thanks!
                              • piopat
                                • 708
                                #585
                                if your laptop / pc has a 9 pin connection you only need a null modem cable to flash the box ,if your laptop / pc does not have the 9 pin connection you need a usb to serial adaptor that connects to the null modem cable .
                                usb to serial adaptors require you to install a bit of software called a driver in your pc ,in simple terms the driver helps the pc see your box (and vice versa) via the adaptor but in my experience windows vista is just about incompatable with the usb to serial adaptor drivers ,in which case if your box is a dm500 you will need to find a desktop pc (with the 9 pin connection ) to flash your box .
                                newer boxes such as a dm800 can be flashed via web browser .
