Guide: Flashing a Dreambox with Dreamup
I had the same problem untill i tried with version dreamup v1.2.2.0 thats the only version that works for me.Attached FilesLast edited by cbk; 20 October, 2011, 13:41.Comment
Hi, I have just purchased my Dream 800 I too never got the instructions but searched about on this forum and managed to find it, all 80 odd pages.Comment
before flashing a dm800 you must know what sim and bootloader version your box is ,most newer clones are sim 2.01 bootloader 75 or 76 (BL75 OR BL76 ) newer boxes are ssl82 . so before flashing your box connect it up and power it up and see if it has an image (an image is the tv software ) if it has an image you can watch the free to air channels .
now to see what particular image you have power off the box (there is a switch at the rear of the box ) and power it back on ,now look at the tv screen and it should say the name of the image such as dreamelite or blackhole /or the GP (the gemini project) or pli etc (if the box has no image you will need to give the boxan image and this is called flashing the box .next you want to know what sim and bootloader version your box is ,so power off the box (via the switch ) and then power it back on and look at the little lcd screen at the front of the box and it will display certain info including the sim and bootloader versions of your box .
so simply put if the lcd display says your box is sim 2.01 and bootloader 76 (BL76) you need an image with the same sim and bootloader versions .if you cant find an image to suit your box before taking a chance and using the wrong image read as many threads as you can on this forum (to find an image ) or ask a senior member on this forum if they can point you to where you can download a suitable image for your box .i love it when a dreambox comes together.
