Guide: Setting Parental Lock on your Dreambox
  • pandokrator
    • Oct 2008
    • 896
    #16
    for deactive pin code (parental lock)
    in all "enigma" images,
    with ftp go to
    /var/tuxbox/config/enigma
    view file called config
    search for parentallock=0000**** the last 4 digit is your code BUT must converting with windows calculator
    from HEX to DEC.
    if you have parentallock=00000906 the result is 2310.
    after that you can disable or change the enigma parental lock code.
    best regards
    e.g. the same trick can used with telnet
    cat /var/tuxbox/config/enigma/config|grep -i pins
    and go to the
    i:/elitedvb/pins/enableparentallock=00000000
    all zeros disabling parental lock code ;-)
    Golden Section
    The Real ART
    • ejaifm
      #17
      Great guide! Thanks heaps
      • BlueBox
        • 573
        #18
        great info thanks
        DreamBox 500HD NewEnigma2
