on pvr dreamboxes does it matter if hard drive is connected or not while flashing
hard drive connected or not while flashing
can you not copy/backup you recordings to a NAS or PC just in case... surely the images record in the same .ts format.. If the data on the hdd gets dicked you could then transfer it back once the drive is reformatted..
Have you got a spare HDD you could try borth scenarios with?
Somebody on here must have been through this and will give a definative answer either way soon....Comment
You can flash your dreambox with the hdd installed no problem. Backup your data first though.D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.Comment
Now M8
never pull the power on a 600 the hard drive might still be spinning. Allways reboot using the option in the menu. it will say "it's now safe to power off" but listen untill you here the hard drive stop spinning. That way the box will remember its settings.
