Hi guys,
I'm using DM800SE on SGSH and the problem I'm facing is this error message:
Service Unavailable!
Check Tuner configuration
I've also tested using DreamElite & OpenPLI firmwares and the error is the same.
I tried playing around with the Menu>Setup>Service Searching>Tuner Configuration with no luck.
What I've noticed is that on my other set which works fine the Tuner is identified as Philips while on the box which isn't working it's more of generic like: BCM4050
Please help
Thanks,
Neo30i
Please help
Thanks,
Neo30i
