Hi Satman. Does your original post contain the correct lib files???
ireland
just one more thing,do we need the hyper cam script installed first to be able to get the cam from the server or can we just grab the cam from there and run it.
Im tinkering around with my 600pvr with a pli jade image on and just need confirmation.Having a bad day today,itgate acting up too but its on the mend as we speak,thanks to satman.sigpicComment
The Cam is from hypercam team, but thats always been there,
someone has just made the keys public to make it work on a dreambox,, needless to say I wasnt involved in this, chances are will just speed up the n3 upgrade, may not even get to see any 'fun' on n2.boom!Comment
Guys, thanks for the fix.. Working a treat.
Can someone tell me what file to edit to get this working as the default cam on startup?
Cheers.
Real men have FTTH.Comment
Checkout the RED stickies massive amount of info and effort been put into them.Comment
Have a look here on this thread:
Lads
I have everything loaded up but missing a couple of channels as in full scan and bruteforce scan are not picking up any of the disney channels tvx etc I've used the ireland cable.xml that was in the download section any ideas? or could someone upload a channel listing or uptodate xml file
ThanksComment
Lads
Did u try a scan on " N**L cable ie " ?
Are you using dk_v1.1 from here? And following the advise step by step from the experts on earlier posts/threads here?
- all channels workin hereComment
did u hold info button down and turn on hypercamLads
ThanksComment
Using Jade PLI image, and have tried the above, I might try and manually add the missing channels if I can, the cam is working fine on all channels, its the missing channels on the scan I'm worried about.Comment
Try a manual scan as follows:
From scan settings screen
Freq=00291
Tick the inv box
Qam 64
Symbol Rate 06887
Check to ensure the Lock and Sync box's auto check themselfs
Tick the network search box
Then start scan,
Should find 13 transponders and 187 services.All information given is for educational purposes only.It is an offence to use this information for the purpose of obtaining free cable and we do not condone the theft of cable services.Comment
Put this into var/etc cables.xml and do a scan,it a bruteforce scan you should choose and all will come in as said above,187 chans on 13 tps.sigpicComment
