Dreambox IP
[QUOTE=jonnboy;221806]Sorry to be a pain,would i be in saying that you have to ftp from the router and pc .
my tele is miles away from the pc,ive tried to get my d500c on the pc,by putting a ethernet cable to my box and router ,nothing happens,i may be doing some thing wrong i dont really know.
help please .
thanks Jon[/QUOTE
if your putting a new image on the box you use a program called dreamup with a null modem cable from pc to box.
it you want to ftp files over to box you need a crossover cable from your pc to the box but uou need to know the ip of the box.
to find the ip of the box use your remote point it at the box with your box on and tv on so you can see what you are doing,and press menu then go to setup and press okthen go to expert setup and press ok, go to communication setup press ok and there is your box ip on the top line.
hope this explains a bit more to you.Last edited by alliv; 1 July, 2009, 13:53.is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
[quote=alliv;221847]Thanks for your reply, is it possible to ftp the file via my lap top and the the box with an ethernet cable?Sorry to be a pain,would i be in saying that you have to ftp from the router and pc .
help please .
thanks Jon[/QUOTE
thanks Jon.............
thanks Jon.............Comment
[quote=jonnboy;222100]as far as i know you need a crossover cable but if you go to your pc store you can get a crossover adapter which you plug onto the end of your ethernet cable. it costs 2-3 quid.is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
[quote=alliv;222158]ALLIV
Sorry to sound thick,lets see. if i get an adapter i can add this to the ethernet cable,then use my laptop and dreambox to fpt the files onto the box.so do i ask for a crossover adapter and they would know what im talking about,as im new to this.
thanks JonComment
Yes the dhcp is set, do i need to have the dreambox connected to the tv, its miles away,so im looking for a solution.
thnaks JOnComment
[quote=jonnboy;222172]got it in one m8. its cheaper than getting a whole new crossover cable. the adapter just crosses over the wires in the connections.is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
You can detect the IP address if toy know the ranges of the DHCP is set to and what is the next one after you PC which might be 192.168.x.3 if your PC is 2 and the router is 1 and nothing else is connected via the router.Comment
