Dm7020 V2 Can't View Channels
If only master ypvs is ard when I start playing dreambox then I wun have lost so much hair...thumb up for u...
Sent from my GT-N7105 using TapatalkComment
Yo can you repost your updated boutique for downloads if you've got E1 and E2. Tks again Cheers
Irregardless of model, dreambox should be able to decrypt all sh channels if correct settings is applied and provided it is using the correct tuner. If your box is able to scan and get the channels, then it is using the correct tuner. I do not own this model but here are some of my suggestion that u can try.
1. Download below the latest bouquet and transfer the files using dreamboxedit to your box as dm7020hd v2 is still using enigma 2 settings.
E2 Bouquet 29MAR14 - Download - 4shared
2. Try out if u can view the fta channels.
3. Fta ok, next go for the encrypted channels and most likely u will not be able to view them.
4. For that, ftp the files to appropriate location as follows,
i) keys folder in usr/keys/
ii) scce folder in usr/scce/
iii) config file in usr/keys/ ...can try and download this one=> mg_cfg - Download - 4shared
5) Install softcam mgcamd 1.31, 1.35 or 1.38 via blue button on newnigma services.
6) Once installed, select the softcam and do emu restart.
Hope that helps.Comment
But then we use dm7020 n 7025 was in 2007 when BOY was around. We gabla so much juz to get box worked for SD chn only. Now new members are so much more advanced in techknowhow, get get SD + HD and with out card!!!! My salute to them
