Q5 PVR scanning new channels
This topic is closed.
  • antking
    • Oct 2012
    • 14
    #16
    Uses manual scan. But my HD5 and HD8 got no sound, only SD channels got sound. Please help. If cannot reply here, can PM me. Thanks a lot.
    • cubert_y
      • Aug 2010
      • 5
      #17
      ANybody can help?when i on my set it will display"BOOT" forever and screen is black.
      • tititortor
        • Aug 2013
        • 12
        #18
        It happened to me before. I contacted the seller and eventually I have to send the box back after receiving a replaced set.
        • tronsmart vega
          • Sep 2014
          #19
          You still consider lucky liao as my seller road run liao, now cannot update firmware.
          • jatrophaseed
            • May 2010
            • 589
            #20
            replace all 5 pc of 470uf and 2200uf (nxt to the big diode), u shud b ok.
            • SGDVB
              • 210
              #21
              @cubert_y... Master Jatro had already advised you of the solution.
              If you open the casing, you should see alot of diode which only 1 is 16v2200uf (green one in pix). If you notice, the diode is abit bloated therefore faulty & causing the stall in booting. Just replace the bloated diode will save your box.
              If you do not know soldering, juz bring your box to sim lim tower to get someone to change for you but must be discreet.
              • SGDVB
                • 210
                #22
                After changing of the 16v2200uf diode...
                • jatrophaseed
                  • May 2010
                  • 589
                  #23
                  also replace the red-arrowed 2 cap with 470uf25v since u already open up the box.
                  • cubert_y
                    • Aug 2010
                    • 5
                    #24
                    Tanks bro..
                    • cubert_y
                      • Aug 2010
                      • 5
                      #25
                      ks
                      Tanks tanks master your help is appreciated
                      • ZAILATINO
                        • Sep 2014
                        Thank u you all
                        • howpeter
                          • Jun 2011
                          • 63
                          #27
                          Hi, would like to know what brand is this Q5 and where can i buy?
                          Thanks very much
                          • SGDVB
                            • 210
                            #28
                            Thanks very much
                            No brand... Juz Q5 as the model I guess, not very sure either but it is quite a simple box to operate.
                            • chyekien
                              • Sep 2014
                              • 8
                              #29
                              My HDC601 is here.... Not very good... Cant see EPL... Can see a while then most of the time keep scramble....
                              Some other channel oso scramble... Dunno if it is due to my internet speed....
                              • chyekien
                                • Sep 2014
                                • 8
                                #30
                                I check with the seller... he say they doing some adjustment tonite... Will be ok after a while.... And now it seems smooth... no more scramble... MY EPL looks perfect now....
