Do these work on any other linux receiver? or they only work on dreambox?
Collection of Plugins for Dreambox
I found this guide
Not sure if its helpful.......
Download Link
Download NFSSETUPANDWALKTHROUGH.zip from Sendspace.com - send big files the easy way
Alternate Link
NFSSETUPANDWALKTHROUGH.zipA wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
Tuxbox
Hi, I'm having similar probs , I've flashed my box but can't use DCC or DB edit as it says the default passwords are incorrect or "Send socket is not connected", even tho the box reacts with a ping test with DreamUp.
How do I put Tuxbox on the DB500s if I can't use DCC or Edit?
I'm a newbie as you'll have gathered!Comment
Problems With DM500C
To Devilfish,
I am super new to this website and I need tech help to re-start the DM500C.
I did a systems re-boot on the unit and would like to check need to install the proper programs from dreamup to the DM500C unit?
Pls email to me at [email protected]
Await for your reply as I am stuck on the technical terms and lingo used for this issue...Comment
To Devilfish,
Can you elaborate what you mean by restart?
Your box does not have the image(program) all along or you reset the box?Last edited by DBTraitor; 5 November, 2012, 05:38.A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
So when you use the nstream plugin for IPTV, did you connect your box to your router?A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
but for your info, not all the iptv channels in the nstream is working. So far i only manage to get a handful only
Moreover, I understand that we need to switch cams for certain iptv channels which I not so keen to explore yet
It has been discussed 3 months backA wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
Yup, some of the channel can. Is there any teletext plugin for SG DM800?Comment
