Please help it says "Service Unavailable, Check Tuner Configurations!"
  • ohmyitseve
    • Jul 2014
    • 9
    DM800 Please help it says "Service Unavailable, Check Tuner Configurations!"
    I have this problem where it says "Service Unavailable, Check Tuner Configurations!
    Here's the pic
    I have flashed it with this
    link 800hd cable 2.01sim 84b - Downloads - Digital Kaos
    here's my box info's
    Kernel version: 2.6.18
    Firmware version: SIM2 patch by GJS
    Gui version: Nov 4 2013
    oh and please note, i am from singapore
  • jatrophaseed
    • May 2010
    • 589
    what is yr box version? is it C or S surfix?
    • ohmyitseve
      • Jul 2014
      • 9
      HI, it is C...im from singapore
      • ypvs125
        • Dec 2010
        • 506
        Do an auto scan or download any bouquet for SG and transfer the files using dreamboxedit. The image that u have flashed is for cable based in uk.
        • ohmyitseve
          • Jul 2014
          • 9
          Thanks a lot for your response, i have since changed my flash image to an Open PLI image(Open+Pli+2.1-dm800-SSL-84b.nfi), i have also FTP'ed the E2 SG Bouquet(Bouquet16062014) that you've uploaded at the Downloads section
          BUT
          When i try to go at the Automatic Scan it says "Nothing to Scan! Please setup your Tuner Settings before you start a service scan" Here's an image
          after which i have proceeded to go to the tuner settings but it says "Zap back to service before tuner setup"
          and i'm back at square 1 where my problem still persist with the "Service Unavailable, Check Tuner Configurations!"
          is it possible that i FTP wrongly? because i followed the tutorial video at
          http://www.youtube.com/watch?v=IlIGkaGKwHA
          but because the video was an old version of dreamedit, i am using the newest version..but so far everything seems norm managed to follow everything exactly BUT the ending part was kinda weird.
          can i ask? can i flash this image for my dm800hd?
          http://www.digital-kaos.co.uk/forums...pdater-429890/
          • pirsquared8
            • Feb 2013
            • 114
            Have you tried to start with the Menu button, go to Setup -> Information -> About to see what is the detected NIMs i.e. Tuner A type? Do you get anything?
            On this page, it shows the image details and also the detected hard disk and tuner
            I reckon the image is not detecting the tuner card
            • ohmyitseve
              • Jul 2014
              • 9
              hello, hi i have done what you said and it says Tuner A: NA(empty)
              now what should i do? can someone please txt me in singapore nine011084six
              oh and i checked my bouquet everything is there all the channels are able to see, just the tuner settings error thingy
              • ypvs125
                • Dec 2010
                • 506
                Open up yr box and try to unplug and plug in the tuner to see if it can be detected, else might be the tuner faulty.
                • ohmyitseve
                  • Jul 2014
                  • 9
                  any idea which is the tuner? ive googled but its so confusing .
                  • ohmyitseve
                    • Jul 2014
                    • 9
                    anyone can help me out?
                    • blueflash234
                      • Mar 2009
                      • 904
                      i might be worth trying another image to see if that picks it up
                      • pirsquared8
                        • Feb 2013
                        • 114
                        Did you try to open up the box?
                        • ohmyitseve
                          • Jul 2014
                          • 9
                          i did, but theres so many stuff in there..and the cable all seems to be connected.
                          flashed 3 different images. same problem.. or do you have any specific image that i should use?
                          • ypvs125
                            • Dec 2010
                            • 506
                            I do not think that it is an image issue since u have flash with 3 different images and still the same result. Problem could be the tuner faulty. The tuner is the one that u insert the cable point. Unplug and plug it back to see if it is detected by the box.
                            • lolipop
                              • 18
                              change your cable
