I'm about to buy a dreambox could someone help me on the steps i need to take to from when i get the box setting it up so i can get all the channels Thanks!!!!!!!!!
Dreambox 500c steps for setting up from scratch
basically
If you read the stickies on the this Dreambox part of the forum. The red ones at the top. You will have so much info in abundance.E Pluribus Unum
From the one to whom much has been entrusted, even more will be demanded!
If you have received help from this post, press the "THANKS" button to show your appreciation. -
take a look at this m8 it puts you on the right tracks then look at the guides
[ame=http://www.youtube.com/watch?v=B7IOS9Yd4oI]YouTube - DREAMBOX 500C TUTORIAL[/ame]Comment
Thank you.- http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
- http://www.digital-kaos.co.uk/forums...nels-uk-48380/
- http://www.digital-kaos.co.uk/forums...reambox-45848/
If you read the stickies on the this Dreambox part of the forum. The red ones at the top. You will have so much info in abundance.Comment
rescan
Hi can any one help me get my channels back? All channels went off, i did a rescan through bruteforce and got all channels back, i then turned the box off by accident and lost them again, doing a rescan isn't bringing them back this time, is there any thing i can do or is it broke now?Comment
Hi i'm also trying to set my dreambox up for the first time. However my problem is that my virgin cable connector wont fit any of the connections on the back of my dreambox. Is there another way to connect this up so as i can recieve the channels that i already pay for on virgin through my dreambox??
ThanksComment
Your Dreambox probably has the RF type connector in the back whereas your Virgin cable has an F-type connector. You should get yourself an adaptor from Maplins or somewhere like that.Hi i'm also trying to set my dreambox up for the first time. However my problem is that my virgin cable connector wont fit any of the connections on the back of my dreambox. Is there another way to connect this up so as i can recieve the channels that i already pay for on virgin through my dreambox??
ThanksComment
