Hi,is it possible to put in new net id on a dm800 se HD c? As when I look in list on box my local one is not shown,nearest on it is miles away!
Net Id's
You don't really need to put in a net id if you do a brute force scan using steps it should find your channels and let you run auto bouquets.
The thing about auto bouquets is it must be run on a working channel.
There is a decent cable image all set up in downloads.
Here you go
Takes bootloader 84b
Word of warning even though I flashed to a sim2 box I got No Ca Found so I flashed 84bl followed by image followed by 84bl again to be safe and got it working. Didn't reboot till last 84bl.
Andy.Last edited by andy91; 5 February, 2015, 12:36.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Go in to your tuner setup you have a choice of scanning in steps and bands choose steps and it should pick up channels.
AndyNew Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Check what db you are getting or snr on the bad channels.
I have the odd bad channel and db is about 29 better channels are nearer 40db.
That could be the reason for picture breakup a bad signal.
AndyLast edited by andy91; 6 February, 2015, 11:49.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
They all to low, way to low.
Either get vermin out or get a yellow konig booster cos the signal is way to low.
