Net Id's
  • accies
    • 95
    Net Id's
    Hi,is it possible to put in new net id on a dm800 se HD c? As when I look in list on box my local one is not shown,nearest on it is miles away!
  • andy91
    • Aug 2010
    • 3583
    You don't really need to put in a net id if you do a brute force scan using steps it should find your channels and let you run auto bouquets.
    The thing about auto bouquets is it must be run on a working channel.
    There is a decent cable image all set up in downloads.
    Here you go
    Takes bootloader 84b
    Word of warning even though I flashed to a sim2 box I got No Ca Found so I flashed 84bl followed by image followed by 84bl again to be safe and got it working. Didn't reboot till last 84bl.
    Andy.
    • accies
      • 95
      What's a brute force scan?
      • andy91
        • Aug 2010
        • 3583
        Go in to your tuner setup you have a choice of scanning in steps and bands choose steps and it should pick up channels.
        Andy
        • accies
          • 95
          The main reason I ask this is ,I'm getting a lot of picture brake up on certain channels ,
          • andy91
            • Aug 2010
            • 3583
            Check what db you are getting or snr on the bad channels.
            I have the odd bad channel and db is about 29 better channels are nearer 40db.
            That could be the reason for picture breakup a bad signal.
            Andy
            • accies
              • 95
              On ch4hd it's 28.3 that's seems to be the worst,it's unwatchable. Other channels all around 31
              • andy91
                • Aug 2010
                • 3583
                They all to low, way to low.
                Either get vermin out or get a yellow konig booster cos the signal is way to low.
                Andy
                • accies
                  • 95
                  Thanks Andy I think il get a boaster, a new spliter as well I think.
                  • cactikid
                    • 12017
                    ahh i will tag along in with net id query which you answered above,on a dm500c on commando image it lists channels on scanning but none found when finished? solo lists channels when pressing up/down button should this not be the same?
