i reflashed my dm 500 all other channels aint there apart from the free channels still aint there ive heard omthing about putting keys into my key folder on the box, But how will i transfare keys from my pc to my box what programme will i use ?
BLACK CHANNELS
You need to use an ftp client to connect to the box.
you need a crossover cable and a programme called FlashFXP or Core FTP
a crossover cable will set you back less than ?10 depending on what length you want.
you will then have to read through the tutorials on here, connecting your box to a PC and ftp`ing ` files across
this is a typical 50 metre crossover cable m8
and while your on get one of these , then your all ready for whatever lies ahead mateLast edited by aftermath; 12 June, 2008, 18:51.
ill get the cable monday i will let u know what happins m8 cheers
<--oweny111 added 0 Minutes and 56 Seconds later...-->
would it be ok if i cut an ethernet cable in half and reversed the connections???
<--oweny111 added 3 Minutes and 44 Seconds later...-->
would it be ok if i cut an ethernet cable in half and reversed the connections???Comment
Sure...just make sure it's wired write!
But if you start to get connection problems, remember you made the cable yourself
oweny i gave u a working DK image for glasgow area wats happened to that??.ive used that saved image 4 times on familys boxes without a problemComment
naa u dont a flashed my own box and sisters box with that image a sent u worked no probs .wen using my image make sure u do this>If you are going to flash a backup image with Dreamup, make sure you select NO when it asks you to flash erase after transferring the image to the box. Or else all your services and bouquets will be set to default.
First many thanks to Mark015 for the image he sent me last night it worked perfect first time. Flashed my box unplugged it attached to the tv and rebooted and everything was back no scanning no adding keys everything was perfect, thank you very very much
Oweny111 I have no idea why your having problems with the flash from Mark015 if you are also from the Glasgow area as his image was a dream come true for me ... You must be doing something terribly wrongComment
no worries andy happy viewingFirst many thanks to Mark015 for the image he sent me last night it worked perfect first time. Flashed my box unplugged it attached to the tv and rebooted and everything was back no scanning no adding keys everything was perfect, thank you very very much
.@ oweny tut tut tut told u it was fine i`m positve u didnt read the tut i sent u ......
