help needed
  • duane100
    • Sep 2009
    • 32
    help needed
    hello everyone
    i need help as i am new to this stuff got a dreambox500c
    and need help installing image on it.
    i have plugged it in and the transponder scan give me two freq which are not the the ones i want as i have a dbox and only know little bit.
    i could do with knowing if can do the image over the eathernet cable or do i need the null modem cable?
    and the programs which i need aswell.
    duane
  • skegsagypsy
    • Aug 2009
    • 1230
    You need dreamup software this is the easiest way to flash, connected to pc with null modem cable. Which image is currently on the box and where are you based ?
    'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
    -Bishop Desmond Tutu
    • bugaloo41
      • 1598
      duane the quickest way to flash the box is with an ethernet cable using telnet. have a read here
      if you are not used to this though skegs is correct null modem and dream up is simple stuff read here
      any probs post back.
      cheers
      • duane100
        • Sep 2009
        • 32
        hi guys
        thanks for the info i am in northwest uk.
        the box has enigma on it.
        • duane100
          • Sep 2009
          • 32
          and another one wat would u say is the best image to put on my dreambox?
          i have now got the null modem cable which looked the simple way for me.
          plus how do i go on with the keys do i need to insatall them on different program?
          • wilf
            • 1618
            everyones got there own preference on image, i use dk on mine and its great. when you go to do the keys i use flash fxp you will need to use an ethernet cable into your router or cross over cable if not http://www.digital-kaos.co.uk/forums...dreambox-1307/
            • skegsagypsy
              • Aug 2009
              • 1230
              You could of course put on an image that is complete but you may as well learn how to ftp while your at it
              • duane100
                • Sep 2009
                • 32
                to start i would like to put a complete image on so can just get it up and runing then i will play a little.
                could u please send me a link to complete image if poss?
                • owen7
                  • Aug 2009
                  • 78
                  Hi mate, seeing as your also from the North West i'll PM you some 'stuff'
                    why pm with stuff why not share it with everyone so more folks can learn..
                    • duane100
                      • Sep 2009
                      • 32
                      right done the image with no problems.
                      went and did a search for transponders and cant find anything.
                      these are the two it is searching which i dont think are right
                      sr6900
                      sr6875
                      how do i change this so can look else where
                      • portbhoy
                        • 717
                        Thats a sat box you have there mate by the looks of it it's defaulted to the sat settings.
                        • duane100
                          • Sep 2009
                          • 32
                          looked at the box and everything else it is all saying 500c even the barcode on the box?
                          • portbhoy
                            • 717
                            Try this image mate flash with null modem and dreamup say no (nein) to flash erase and do not factory reset, when image is on just scan RapidShare: 1-CLICK Web hosting - Easy Filehosting
                            • duane100
                              • Sep 2009
                              • 32
                              ok no probs will give it a go
