DM500C unable to work after changing image - Advice needed
  • jp376
    • Sep 2009
    Hi All
    I live in sg and had a Dm500C which was working fine a few weeks ago. The image is Nabilsat Darkstar 2 and it is using mgcamd 1.31.
    However a few days ago , I see all my channels but i can blank screen so i did the following after reading the noob guide in the download section.
    I connect a null modem to the box , erase flash and flash it with dk1.1 and using evocamd as the emu.
    Next using flashfxp , uploaded the keys and roms to /var/key and /var/scee.
    I did a bruteforce automatic scan but i am unable to scan any services not even FTA.
    I read through similar threads and repeat the steps however the results are the same, (unable to get any services nor FTA)
    Next i did a manual transponder scan and i managed to scan some services and retrieve back FTA.
    Next i press on info for 3 secs and restarted evocamd. Then I try to select one of the channels , however it comes up as blank screen. i press on "info" and select streaminfo , i am able to see the PID , SID etc and on the last page of the info , i can see the lock and sync checkboxes are ticked
    This is the same for all other channels -> blank screen when selected although evocamd shows the title of the show and next programme etc.
    Since then , i am struck at this stage and had been scratching my head.
    I would really appreciate and thankful for any advice/help from the gurus in this forum
    Thanks in Advance
  • challah
    • 242
    where is sg and what roms and keys did you install
    • jp376
      • Sep 2009
      Hi
      Sg is in singapore. The attached is the roms and keys i am using
      • jp376
        • Sep 2009
        Originally posted by jp376
        Hi
        Hi
        Seems like the bmp parameters are beyond the limits set and i am unable to upload then
        Below are the keys/roms i am using.
        Roms
        nagraepr7
        nagraepr11
        nagraram10
        nagrarom7
        nagrarom11
        nagraepr10
        nagraram7
        nagraram11
        nagrarom10
        Keys
        AutoRoll.Key
        Autoupdate.Key
        camd_cfg
        gbox_cfg
        Keylist
        nagra
        services
        SoftCam.key
