Is this normal
  • masur123
    • Aug 2009
    • 674
    Is this normal
    When I turn on my dream box I can get a black screen for up to 10 minutes, but other times it can clear in seconds. Am i doing something wrong?
  • aftermath
    • 4345
    could be a TV issue, maybe the input for the dreambox isnt kicking in right away ( are you using a scart lead ) .
    also put onto a free channel then re start the box, see if a free channel clears straight away. ?
    • masur123
      • Aug 2009
      • 674
      Yeah I am using a Scart lead, and its the same for all channels, whether they are FTA or not. Its a little odd? Also I can hear sound immediately
      • Sicilian
        • 168
        Have you tried hooking upto another tv via scart? Or using another scart socket on the same tv, if possible?
        D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
        • aftermath
          • 4345
          also replace the scart lead with the video leads ( red,white,yellow) leads
          that might do the trick.
          also check all your settings for dreambox, it might be something stupid like its doing a scan or a hard drive check or trying to do an EPG scan or something on startup
