hi i have a dreambox 500c and have dw2.1 on it. seems that i can c all the channels but its jumpin and breaking up every few seconds. this only has been happenin the last few days. Any ideas as to why this is happenin
pic breaking up every 2 or 3 seconds
Disconnect all your coax, check the connectors are on properly and reconnect making sure everything is tight.
Menu > Information > Stream Info > Right Right Right
SNR % should be mid 90s, 96% is ideal.
Less than 90% and you risk breakup and freezing. Signal booster would be required to boost the signal strength or remove all splitters and put the box on the main feed and see if the SNR % improves.Comment
I have had the exact same problem (here in surrey ex-tw) for the last week or so and a mate of mine has had it too in crystal palace area (ex-tw) i am using v+ boxes and dreamboxes he is using v+ only, It has to be virgin doing somthing as we are on diffo gateways as we are 10 miles away from each other.
As far as signal goes its funny how it seems to of dropped since we went over to virgin ???Last edited by pacman362; 26 June, 2008, 08:30.Comment
if you're looking for a good booster try this.
good booster and a dam good price...
(No, I'm not the seller
Mubz
Growing old is inevitable, growing up is optional ...Comment
Same thing happened to me from Sunday to wed night all channels jumping breaking up. I didn?t get round to doing anything about it and it cleared itself by wed night!! Strange but do think it could be a fault on the cable company or something more sinister! im paranoid again!!Comment
Do you have a subbed box on line as well, as i had a sammy that caused so many sig probs. As soon as removed no probs, also your splitter could be the problem, just disconnect and single supply to problem box if all is ok replace splitter, check conections.
Also ensure vmedia filter is fitted prior to any box.
Found also latest cams caused probs, try evo 2.14 and mg 1.16.Comment
