No Channels Found
  • MILLWALLFC
    • 173
    No Channels Found
    First of all apologies for asking another question but i am a complete newbie. I have managed to Flash my box with pli-iolite-dm600pvr-20071230-4014.nfi and i have run the scan channels Auto but no channels were found.
    Is there anything else i should be doing i have found a manual scan should i use this and what Freq should i add.
    I am in a cable area Ex CW do i have to add files to see anything i have read somewhere about a Cable.xml file ?
    This is the exact message
    "All known transponders have been tried, but no lock was possible. Verify attenna / cable setup or try another Satilite network."
  • satman
    • 736
    were you trying to scan the default options? they are not uk symbal rates,
    uk is 6887 and 6952,,,,,, ( not 6900 etc )
    add a uk cables.xml by ftp... or use a uk-ready image,,,or even pli backup someone may have added the correct cables.xml
    boom!
    • MILLWALLFC
      • 173
      Thanks just need to find that cables.xml file now. The only thing i think i may have found on rapidshare is a keys folder that may come in handy.
      Also i would assume the cables file would be put here to overwrite this one.
      \\192.168.1.103\Configuration\etc
      • satman
        • 736
        look no further,,,,, tho i sure it will be on here somewhere already
        boom!
        • MILLWALLFC
          • 173
          Cheers the other location it could go is here.
          Do you know which one.
          \\192.168.1.103\Configuration\tuxbox
          Thanks for the file. i owe you a beer.
          • satman
            • 736
            Sorry i am not use Pli image so could be anywhere, but if you look it your box for the current cables.xml just overwrite it..
            it will be in a tuxbox folder somewhere,,, either in /etc or /usr usually...
            boom!
            • MILLWALLFC
              • 173
              there was a file there cables file there " tuxbox " which i replaced and it seem to do them all. Do i need to reboot box and rescan as it still seems to not pick anything up, just says scanning 378 / 6900. Im assuming scanning 6900 is no good.
              • satman
                • 736
                nah 6900 is no good,,,,,
                one of the pli users will advise you better where it needs to go mate..
                boom!
                • westkill
                  • 2378
                  reboot and see if it gives the uk xml
                  • MILLWALLFC
                    • 173
                    Think a reboot worked its now scanning 6952.
                    Should i scan "6887" after to this one has now found a transponder and says 7 minutes left.
                    Got some free to air ones now, just scanning 6887. There are some others in the list do you scan them all to get other channels ?
                    Just another update have now scanned all channels and only picked up FTA TV. :-(, not sure what to do now.
                    • westkill
                      • 2378
                      ntl area is 6887
                      telewest area 6952
                      • satman
                        • 736
                        now you add the magic keys folder you said you had found and add evocamd
                        boom!
                        • MILLWALLFC
                          • 173
                          Cool im NTL C&W area, i scanned that but only got FTA channels. Not sure how to get others, it did not find them on scan.
                          <--MILLWALLFC added 0 Minutes and 46 Seconds later...-->
                          ah ok.
                          I have added the key folder but not sure what "evocamd" is and what to do with it.
                          • satman
                            • 736
                            ah ok.
                            evocamd is a softcam that reads the keys ,,,,
                            probably downlaodable from the Pli panel
                            boom!
                            • MILLWALLFC
                              • 173
                              Taking a look but can only see images at the moment.
                              Have downloaded, cccam-2.0.9
                              Any idea where i put unzipped files and do i then have to rescan ?
                              Just read this on this Forum "The Pli team already have this on their download server. Use the Blue button > Software management > Downloads > Softcam > Evocamd 2.... It will install automatically once you download the file from their server."
                              Would that do the trick ?
