No Channels Found
  • westkill
    • 2378
    #16
    keys and scce files gointo /usr/
    if i remember correctly there might be a keys and scce file already in the image so delete them and put the new ones in
    i dought cccam will work
    you realy need evocamd
    have you got all your channels scaned yet
    • MILLWALLFC
      • 173
      #17
      Yes all channels scanned but can only view FTA nothing else.
      I did this but it still never worked. Looks like i need to find that file.
      Just read this on this Forum "The Pli team already have this on their download server. Use the Blue button > Software management > Downloads > Softcam > Evocamd 2.... It will install automatically once you download the file from their server."
      file structure below for 600pvr box.
      • satman
        • 736
        #18
        do what it tells you and look for evocamd, i am about 99% sure they will have it on there download panel if its connected to net...
        boom!
        • MILLWALLFC
          • 173
          #19
          This is what i installed
          • satman
            • 736
            #20
            yes that should do the trick,,,, now if your key files are ok, you want to make evocamd your default softcam ( blue button usually ).,, and leave on a premium channel for a few mins
            boom!
            • MILLWALLFC
              • 173
              #21
              i set it to Default softcam have gone on preium channels no joy, just rebooted box and no joy. I can only assume i have put keys in wrong place or they dont work.
              • westkill
                • 2378
                #22
                did you put both keys and scce files in /usr/
                • MILLWALLFC
                  • 173
                  #23
                  I think i need to do two things, find out where the latest keys are and how i upload to that folder "USR" In the file structure on the 2nd page its not there, but if i browse using Internet Explorer i can see it but not sure how to upload there, may try an FTP client.
                  Can anyone PM where i can downlaod lastest keys to make sure i have the right ones.
                  • satman
                    • 736
                    #24
                    Any keys will do as long as they have the fixed AU roms,,, as it will autoroll the latest keys......... and there on a link on here somwhere
                    and in intenret explorer click, open in windows explorer,,,,
                    or use a FTP client like you say..
                    p.s check your pm
                    boom!
                    • MILLWALLFC
                      • 173
                      #25
                      now have working keys in "scce" and "Keys" folders. but cannot get itto any other channels over than FTA. I have pushed blue button and set "Default Softcam" to evocamd 2.27b but no joy.
                      It must be something very simple im doing wrong.
                      • westkill
                        • 2378
                        #26
                        did you reboot after adding the files
                        • satman
                          • 736
                          #27
                          press Green to restart cam,,,, if not open after a few mins you not put the ones i sent you in correct place,,,,,, or there is conflicts in your .var and /usr
                          boom!
                          • MILLWALLFC
                            • 173
                            #28
                            I did a restart and just tried a hard reset, e.g. pulling out power cable still no joy. When you push the blue button to install things there loads of things there do i need to install anything else ?
                            • satman
                              • 736
                              #29
                              evocamd config .....
                              boom!
                              • westkill
                                • 2378
                                #30
                                if it still dosent work try this it happend to me once before
                                go into /usr/ delete keys and scce
                                then
                                go into /var/ delete keys and scce
                                go back to /usr/ and replace keys and scce files
                                restart the box
                                might help
