IR receiver broken :(
  • Gun_Man
    • 102
    DM500 IR receiver broken :(
    I have a Dream Box DM500 and the infrared receiver inside the box dose not seem to work. I have look through the RS catalogue and they seem to sell many types. Dose anyone know what type of IR receiver (diode/LED) these boxes have in side them? If so where can I get one?
  • dancemonkey
    Have you opened the box? I had the same thing happen to mine, cracked it open and found the flat cable between the main board and the sensor board had come loose.
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      This has also happened to me before. Do you see any green or red leds on the front or is it just blank?
      • ZooLio
        • 40
        yeah, this has happened to me a few times. if you've not opened it up, open it up might be as simple as re-plugging in the cable.
        alternatively, if you bought from a 'reputable supplier' then they might replace that particualr module, thus saving on the postage costs.
        • pawcook
          • 18
          I have the same problem at the moment with a new box I just got. I'm in talks with the supplier at the moment to get the board replaced. With mine it just about works if the remote is about 6in from the box, it is definately the infra red detector board as I have swapped it with one from my other box. If anyone knows which detector is used on the board I would be interested to find out as well.
          • xion2000
            • 16
            Remote IR board faulty
            I have exactly the same fault on a box I received today. I bought the box from a trader in China through the ioffer website.
            Anyone have any ideas on where to get spare parts from??
            • smokey_jnr
              • 380
              PLEASE could you let me know also, my dreambox is doing the same thing as long it's in line and only a foot away it's fine..
              so if there is somewhere to get this part that would be great.. i have tried opening the box once before but could not see a cable, but will check again..
              • smoggie
                • 863
                look at pic you can see the lead on remote ir board
                • smokey_jnr
                  • 380
                  where is the LED.../??
                  • smoggie
                    • 863
                    the ir board is circled in red, remove the screws and you will see the leds
                    • ronlkh
                      • 74
                      sometimes is due to hairline crack on the IDC connector solder
                      • smokey_jnr
                        • 380
                        the power button on my box is stuck would that cause a problem with the sensor not working properly..??
                        do these remotes work on IR or RF..?
                        • dreadfand
                          take a picture of the receiver inside the box and post it on a forum relative to the subject matter...... I'm sure someone in the know can tell you what it is and you can find a replacement.
                          • ric
                            DM500 IR RECIEVER BROKEN
                            HI
                            have you tried a universal remote for dreambox recievers all types
                            They usually have intructions how to put in codes etc
                            or you could order from the Dreambox company who makes the recievers
                            I understand the software is Linux also i've used linux typing this message to you
                            hope this helps
                            • dreadfand
                              Originally posted by ric
                              HI
                              hope this helps
                              as far as i can tell the problem is with his receiver not his transmitter i.e the bit in the box
