dreambox 7025 cable
  • minster
    • 13
    dreambox 7025 cable
    my dreambox 7025 is running PLI jade 3 it is working fine on satellite, but i have just fitted a cable tuner but when i do a scan it picks up no cable channels. do i need to alter any settings in the cable tuner config. i am in the ex cable and wireless area ie manchester
  • SatSearching
    • 447
    You need to manually set up the scan settings for the C tuner.
    Type of scan = single transponder
    Frequency = (whatever your freq is)
    Inversion = Auto
    Symbol Rate =(06952 or 06887)
    Modulation = 64-QAM
    FEC = Auto
    Network Scan = yes
    SS
    • minster
      • 13
      frequency
      i checked what my frequency was and its 666.750 but there is only 3 spaces to enter the frequency in
      • loader626
        do an automatic scan after setting symbol rate to 6952 and changing network scan to yes
        • on_the_jazz
          • 557
          If nothing is found on 666, try 000 too.
          • pegasus29
            I am a newbie to this site. Having browsed a couple of other similar forums I decided that Kaos was the one to subscribe to. The others seems a lot less flexible.
            I'm looking forward to learning and becoming an active member!
            • minster
              • 13
              ok thanks guys got all channels scan in. but need need some more help only getting fta channels. i am running cccam 1 x sat tuner and 1 x cable tuner PLI jade 3 image
              • SatSearching
                • 447
                Just 666 only should be good enough for a scan.
                What image are you running? CCcam will clear but WON'T au nag1......
                Try Mg or Evo for AU
                • minster
                  • 13
                  running PLI Jade 3 tried cccam and wont clear but got it working with mg but have to change cam back to cccam for satellite which is a bit of a pain
                  • on_the_jazz
                    • 557
                    Run cccam, edit your SoftCam.Key, remove everything but the rom7's and change the id from 5401 to 5501 on each line.
                    Restart cccam.
                    (thanks to despdan for this tip).
                    • minster
                      • 13
                      edit softcam as you said
                      deleted everything but rom7.bin and softcam.key from var/keys
                      deleted everything but rom7.bin from var/scce
                      still no clearing with cccam
                      does any need chmod
                      • on_the_jazz
                        • 557
                        does any need chmod
                        Sorry I should have been more clear, I meant remove all lines apart from rom7 ones from softcam.key. Everything I have written is for things to be edited in softcam, don't delete anything else
                        • minster
                          • 13
                          N 5501 00 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Sun Oct 18 17:54:30 2009
                          N 5501 01 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Sun Oct 18 17:54:30 2009
                          N 5501 00 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 07:59:33 2009
                          N 5501 01 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 07:59:33 2009
                          N 5501 00 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 08:02:44 2009
                          N 5501 01 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 08:02:44 2009
                          this is what i have in my softcam i have put x's in for the real keys but still no joy with cccam works fine if i use mg cam
                          • mini
                            • 602
                            Are you suing the rom7 from the november update?
                            • kwasiarsenal
                              • 30
                              I have the same box and using newnigma2 v2.5 and both sat&cab are working on cccam2.1.1newsccam1.67. go get latest satankeys and put the var/keys, var/scce in the box. If it doesn't clear, find latest sofcam.key by KM and rename it exactly as the softcam in var/keys and replace it. it should work.
