my dreambox 7025 is running PLI jade 3 it is working fine on satellite, but i have just fitted a cable tuner but when i do a scan it picks up no cable channels. do i need to alter any settings in the cable tuner config. i am in the ex cable and wireless area ie manchester
dreambox 7025 cable
You need to manually set up the scan settings for the C tuner.
Type of scan = single transponder
Frequency = (whatever your freq is)
Inversion = Auto
Symbol Rate =(06952 or 06887)
Modulation = 64-QAM
FEC = Auto
Network Scan = yes
SS -
Run cccam, edit your SoftCam.Key, remove everything but the rom7's and change the id from 5401 to 5501 on each line.
Restart cccam.
(thanks to despdan for this tip).Comment
Sorry I should have been more clear, I meant remove all lines apart from rom7 ones from softcam.key. Everything I have written is for things to be edited in softcam, don't delete anything else
N 5501 00 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Sun Oct 18 17:54:30 2009
N 5501 01 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Sun Oct 18 17:54:30 2009
N 5501 00 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 07:59:33 2009
N 5501 01 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 07:59:33 2009
N 5501 00 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 08:02:44 2009
N 5501 01 xxxxxxxxxxxxxxxxxxx ; ROM7 AU Key Time Tue Oct 20 08:02:44 2009
this is what i have in my softcam i have put x's in for the real keys but still no joy with cccam works fine if i use mg camComment
I have the same box and using newnigma2 v2.5 and both sat&cab are working on cccam2.1.1newsccam1.67. go get latest satankeys and put the var/keys, var/scce in the box. If it doesn't clear, find latest sofcam.key by KM and rename it exactly as the softcam in var/keys and replace it. it should work.Comment
