hi guys i was inside the box to put a hard drive in and took out the ribon cable going to the front of the box where the power button and the lights are. now i,ve put it back together the light only goes red and the remote wont work with it. any help would be great.
only red light on front
u might be barking up the wrong time m8 .. red time is hard drive .. sounds like the harddrive isnt in right to me .. up plug the drive and see if its ok thenany information provided is for educational/experimental purposes only.Comment
if u have a lock out u need to boot box from wall plug while its sending the firmware . but if the harddrive in wrong the box will lock outany information provided is for educational/experimental purposes only.Comment
got it sorted.it was the pins on the power switch ,there was 4 rows of pins and 5 rows of holes on the block. it was in the wrong set of holes.thanks for the help guys and i hope this helps someone else. now to get my dreamup sorted..........
is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
