the reason you had the no carr error was due to your bootloader (second stage) I had exactly the same problem, I can upload the bootloader, it take les than a minute to flash, Like i said, i can upload the camd files but no idea how to install, I searched and read for over 2 weeks before i could fix mine.
800hd scanning for channels
It would be good if you could upload camd m8. By second stage bootloader do you mean the flash in dreamup 1.3.3.3? Should I have flashed the backup and then loaded the dreamup flash?the reason you had the no carr error was due to your bootloader (second stage) I had exactly the same problem, I can upload the bootloader, it take les than a minute to flash, Like i said, i can upload the camd files but no idea how to install, I searched and read for over 2 weeks before i could fix mine.Comment
The best thing for you to do is to flash the backup then, proceed to flash the Bootloader which takes less than a minute and you are sorted.Comment
err 01 no CA found = no secondstage bootloader on the unit.
Happens as you have flashed an image into the box. Or could happened as bootloader has become courpted.
Just flash using dreamup a new bootloader, fixed
Cheers, Bonesy.
Got this working using your image and rescanned channels. The one problem I have is that the channels cut out every couple of minutes saying service unavailable, check tuner configuration. The coming up DVB service NA along the bar at the bottom of the screen where the channel info appears? When I go back into the channel list and select the channel it comes back on again for a few secs and then back through the cycle? Anyone any ideas?Comment
try a different cam, i use mgcamdWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
I have gott my DM 800hd which have DVB-C tuner. I live in London and I dont know what type of cable needs to be connected?
I have virgin media cable is this cable do I need to connect to my dm or I need TV aerial cable to connect to my dm?
Please help I have tried to connect virgin media cable to my dm and try to scann no channels comes up.
I have Pli image installed and have tried to put cable.xml still no luck.
Please help me how to connect my dm800 hd pvr with DVB-C and what type och cable I need to connect and how do I get channels.
Thank youComment
