green led fix after flash
  • nono_748
    • 61
    DM500 green led fix after flash
    Hi all,
    After flash my DM with flashwizzard 6.3 and DK image, I deconnect and reconnect my DM and red led fix, nothing with the remote control.
    I would like to reflash with dreamup but after conneting the laptop and the DM via null modem cablem, select COM1, connect, I connect my DM but dreamup say all the time "connection prepared, now switch on the dreambox!" and after maybe 2 or 3 minutes, the led switch off and no led on the front
    I'm sure the DM start because when I connect the ethernet cable, I have confirmation connection but nothing and impossible to switch off with the swith facade button
    Have you any idea ?
    Thanks for your help
    Nono
    Atlas HD200se F404
    vu+ solo suptv + Ncam for TNT card V5 openpli 4.0
    vu+ zero script openpli 6.2
    Sunray 4 openpli 7.0 suptv
  • Bonesy
    • 655
    was the remote working before you flashed it? If so it could be just a bad flash.
    If it wasnt, then check the cable in the unit hasnt come loose.
    • nono_748
      • 61
      Hy Bonesy,
      Yes the remote working before.
      I think it's just bad flash but I don't know to reflash the DM
      Nono
      Atlas HD200se F404
      • smirnoff_rules
        • 8603
        use dreamup and a null cable . turn the box off at the plug and then as your sending the firmware(or connecting to the box) turn the box back on at the plug
        • dedea
          • 5
          What version of dreamup you use,try with couple different dreamup versions maybe will work.
          regards
          • Bonesy
            • 655
            have had this happen to myself, use dreamup, and reflash the box using null modem cable. NOT ethernet.
            • nono_748
              • 61
              Thanks guys for all informations.
              I trying and tell you
              Nono
              Atlas HD200se F404
              • nono_748
                • 61
                After burned my fingers for craeted a null modem cable, I reflash my DM with DK image and everything is ok, just need to reinstall cccam, keys and scce.
                Thanks all for your help
                Nono
                Atlas HD200se F404
                • lynas1234
                  • Feb 2011
                  • 8
                  Hi i've had the same issue,
                  i think i may have done a bad flash on my dm500s,
                  i flashed the box and it got to about 84% and stuck,
                  now the box just switches on with a solid green light and nothing on the screen, it doesn't get an ip address,
                  and now won't communicate with my computer i've used various versions of dream up and a null modem cable, also i have tried a computer with a pci serial port and a computer with an onboard serial port and still nothing.
                  is there anyone that can help me sort my issue, or is it totally bricked?
