No sky1 DM500C
  • shipdus
    • 20
    No sky1 DM500C
    Hi, im having trouble picking up sk1 on my dreambox, i can pick up every other channel, except sky1.
    Im on dk v. 1.1 image. I've tried every scan, but no luck, disconnected all coax and reconnected, nothing.
    I've got a eurovox in my living room, and it picks up sky1. I don't know what to do now.
    Does anyone have the manual PID's for sky1?
    Please help!! Thanks in advance.
  • alexh
    • 225
    You should be able to use the eurovox to find out the frequency & symbol rate for the transponder containing Sky 1. (Which will be unique to your cable area)
    Then on the dreambox use the remote, press Menu->Setup->Service Searching->Manual Transponder Scan
    This dialog box opens and add the frequency & symbol rate from your Eurovox and press "start scan"
    • shipdus
      • 20
      alexh, thanks for the reply. Tried it, no luck. Do u have the PID's for sky1?
      • micron123
        • 24
        500C and sky 1
        I've seen this problem. Sky1 is at the bottom end frequency range (131MHz) and the DM500 is not great at that frequency. You will probably find the signal is too low and your box is not seeing it. If you use a booster to increase the signal level it will probably be ok.
        TPID 5513, TPID 577, APID 641, PPID 34.
        • shipdus
          • 20
          thanks for reply, will try the PID's if not, does this mean i have to buy a booster? i pick up every channel, except sky1, i dont want to buy a booster just for 1 channel.
          • halau
            • Aug 2008
            • 278
            was just reading this post as i have the same problem with sky one, my signal is at 96% cant see a booster would do much
            • alexh
              • 225
              Originally posted by shipdus
              Tried it, no luck.
              Assuming you used the correct frequency & symbol rate for your area, your receiver is not capable of getting that transponder. Perhaps the signal is too weak or too strong or has interference.
              The first thing to try is to follow the cable back to the wall and remove the Y-Splitter and try the cable direct. If that does not work you need to try a variable attenuator in case the signal is too strong or has interference.
              http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=190213021306
              Finally try an amplifier.
              http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=260496225760
              PIDs are useless unless you know which transponder frequency to use. Do you? Are you going to try each one? You'll be at it for weeks.
              Sky1 is not on a transponder on it's own. You must have other missing channels, perhaps obscure ones or +1 ones.
              • cgscott
                • 3513
                Try buying an attenuator. This way you can vary the signal strength. I think 96% is a bit high.
                Search this in ebay. You want a 0-20db gain attenuator.
                Cable TV Attenuator
                This will solve your problem no end.
                Patience is a virtue.
                • alexh
                  • 225
                  Not at all. Mine ranges from 95% to 98%.
                  Still if removing the splitter from the cable doesn't help (just while you tune in), try an attenuator first, much cheaper than an Amplifier.
                  • cgscott
                    • 3513
                    Yes but it wont register too strong a signal therefor an amplifier would be useless.
                    Hence the reason i suggested an attenuator.
                    • shipdus
                      • 20
                      so if i purchase a variable attenuator will this fix my problem?
                      • alexh
                        • 225
                        Depends if this is your problem and not user error.
                        Worth a try.
                        • shipdus
                          • 20
                          alrite will do, thanks for the help alexh
                          • punxxxter
                            • 184
                            hi mate
                            i had the same problem, no sly 1. i scanned again in bruteforce for UK and its now there. Hope this helps....
                            • shipdus
                              • 20
                              punxxxster what area do you live in? ex ntl or ex tw?
