dm800s please help
  • jims
    • 54
    dm800s please help
    Hi all
    I ordered this one from linuxsat and having a few problems with it
    dm800s with bl72 gemini pre installed
    the only way it will power up is if i hold down the power button
    while hot plugging power supply it usualy takes 5 or 6 attempts somtimes it will not power up at all
    sometimes flash mode or
    dream multimedia on the lcd screen
    i have flashed with NabiloBlackHole-12-BL72-DM800 over web interface
    still problems booting
    Ip is unconfirmed in network setup
    ftp is working with a static ip but no internet connection
    using the same cable my dm600 uses, so i know my network is ok
    nabilo restart. hard reset are not working
    reflashed with NabiloBlackHole-11-BL72-DM800
    same result
    reflashed bl72 with DreamUP_patched_by_forhike_and_natas
    reflashed with NabiloBlackHole-12-BL72-DM800
    same result
    could the power supply be faulty?
    please any help will be much appreciated
  • Superman
    • 520
    Sounds like a faulty power supply, try a differnt cable if you have one, there usually the same as laptop cables (some model of laptop)
    • jims
      • 54
      SuperSatShop.eu
      many thanks
      turned out to be only the cable
      • Superman
        • 520
        Glad your sorted mate
        • halau
          • 278
          just a general query as i am having similar problems
          how and why was it your cable as it works fine on your 600 you say
          • jims
            • 54
            it was the short piece of cable from the plug to the power supply
            i replaced it with one that has a uk plug
